Hi, we are flying Upper Class next year from Manchester, does anyone know if you can take a guest into the Escape Lounge. Thanks.
I assume so if your friend is flying on the same flight as you and you request an extra pass if they do not check in with you
They no longer issue lounge passes at MAN - they just tell you to show your Upper Class boarding pass / FC Gold card at the lounge. But as above, the lounge should know it's OK for a UC / Gold pax to guest someone in on the same flight.
Asked at Disney Springs check-in a couple of weeks ago about guesting at MCO (for a trip in 5 weeks time) & they confirmed all is OK. Check in together at UC desk and the other passengers boarding pass will be stamped for both TSA priority lane & Delta Sky Club access.
Users browsing this forum: No registered users and 122 guests
