#810195 by slinky09
09 May 2012, 11:00
Hiya - just lately I've noticed that when I click on the aeroplane icon under peoples' names in post, the chart doesn't load. Works sometimes for some people but not others, see below. Am using Chrome release 18.0.1025.168 on a Mac.
#810198 by stevebrass
09 May 2012, 11:23
Same here except windows 7.
No problem with Firefox.
#810236 by CHill710
09 May 2012, 16:20
if it helps i have the same issue on a few people (i have just checked) using safari on a mac book.
#810241 by Neil
09 May 2012, 18:00
We did have some issues a couple of weeks back, and as Pete was away and unable to fix them I think he disabled the feature.
Sure he will be along to confirm/advise on it at some point.
#810245 by honey lamb
09 May 2012, 19:41
Neil wrote:We did have some issues a couple of weeks back, and as Pete was away and unable to fix them I think he disabled the feature.
But he restored it since then, Neil and it has worked since then. It seems to be random as to who is able to view it as it's fine for me
#810264 by Pete
09 May 2012, 23:28
Sorry, should have mentioned this - we had a denial of service attack or leach picking on the code that displays that map in particular, so it's been disabled temporarily until the problem goes away. They normally get bored once they realise the resource has been turned off.
#810274 by slinky09
10 May 2012, 06:54
Pete wrote:Sorry, should have mentioned this - we had a denial of service attack or leach picking on the code that displays that map in particular, so it's been disabled temporarily until the problem goes away. They normally get bored once they realise the resource has been turned off.
Thanks - odd thing is though it works for some users, not for others?
#810276 by Slipperman
10 May 2012, 07:11
And not consisently for them either. I can see every map on this thread... except for.... Slinky09's ?|
#810311 by CHill710
10 May 2012, 13:39
it is not just you it is only Slinky's map that i can't see now.
#810312 by slinky09
10 May 2012, 13:49
:0 :0 ?|
#810324 by tontybear
10 May 2012, 15:21
slinky09 wrote:
:0 :0 ?|
Same for me too - only Slinky's map is a secret!
MAybe if he did the old log off and on again that might sort it?
#810329 by slinky09
10 May 2012, 15:42
tontybear wrote:MAybe if he did the old log off and on again that might sort it?
Tried that :#
#810396 by Pete
11 May 2012, 07:06
Slinky's issue appears to be something unconnected to the temporary switch off (now switched back on). Probably something in his itinerary that the code is failing on - I will investigate...
#810564 by slinky09
12 May 2012, 19:39
Pete wrote:Slinky's issue appears to be something unconnected to the temporary switch off (now switched back on). Probably something in his itinerary that the code is failing on - I will investigate...
Perhaps Cancun is upsetting things?
#810591 by slinky09
13 May 2012, 09:53
Pete wrote:Nope - it was BER - Brandenburgh wasn't in the database. But now is, so fixed!
Thank you Pete, now it seems that I won't be going to BER since it won't be open by then, but great!
Users browsing this forum: No registered users and 57 guests
