Thanks all for the advice thus far...
Originally posted by HighFlyer
Was it the Sony Earbud system you had?
Yes it was - well, still is as long as the stripped wire hangs together! They've served well given the bashing I've given them in trains, planes and buses (the thrill ride that is the Lothian Bus 22 service between The Gyle and Ocean Terminal).
Having the new 160 GB iPod Classic has increased my use of same and earphones. Not only do I not have to make 'x or y?' decisions on what to load anymore (so can mix music, comedy, recorded word and podcasts and hence have something appropriate to almost any mood) but also the battery life is soooo much better than my previous model, which would only give me a couple of hours of continuous use and would be subject the battery drain even when switched off.
Paul
