#20862 by JAT74L
31 Aug 2007, 14:03
Hi all,
Would I get BA tier points when flying on American Airlines First class from LAX to LAS? The fare code seems to be a K-UP while the fully flexible First ticket is a Y-UP.
John
#182385 by Howard Long
31 Aug 2007, 14:22
My understanding is yes, you would get 60 TPs. Although it's an upgrade fare, it's an instant upgrade at the time of booking.
I see it's discussed over on FlyerTalk here
Howard
#182386 by JAT74L
31 Aug 2007, 14:27
Cheers Howard,
Flying LAX - LAS on AA is now looking like the preferred option over the Corvette!
John
#182390 by Howard Long
31 Aug 2007, 15:10
Originally posted by JAT74L
Cheers Howard,
John
I must admit I have switched to driving since 9/11 on this route, although LAS has since improved, having priority lines.
Howard
#182402 by jaguarpig
31 Aug 2007, 16:37
K-UP is the new code for Y-UP, both are the same thing and you will earn 750 miles and 60 TPs.Present your BAEC card at check-in and make sure that the BP has your EC number on it,miles/TPs post in about 5 days.Don't expect much from these short AA F flights and there's no lounge access unless you hold BA silver or above.
#182404 by JAT74L
31 Aug 2007, 17:07
Jeez, I should've thought about this before I booked VX to SFO as going back to LAX then up to SFO all on AA would have netted me enough TP's to clinch BAEC silver.
Drat.
John
#182406 by Bazz
31 Aug 2007, 17:39
John, I'm sure Iain will make it up to you by rewarding you with copious quantities of alcohol in return for your company on the VX leg ;)
#182407 by JAT74L
31 Aug 2007, 17:44
He's not been on since I booked it so has a PM waiting to be read!
John
