McMaddog wrote:Yes I logged in fine through the homepage just not able to show the iFrame style popup login form from the top of the screen link. The offending link sits next to the Text size +/- bit on the grey bar. It definitely used to work in the early days though the text size on the popup was always rendered wierdly (way too big).
I tried it on my install of IE8 (8.0.7600.16385) on Windows 7, and it worked ok (you should see a box like this when you click Login):
Which leads me to believe that the code is probably ok, but there's something else in your particular configuration that is clashing with it. Do you have any third party extensions like Google Toolbar, etc, that can be temporarily disabled to see if they're interfering with the site operation? Have you got any of the Microsoft "InPrivate" settings enabled? Can you think of anything which would make your install of IE8 not as standard as another one?
Pete
