#773439 by HWVlover
31 Mar 2011, 16:38
This doesn't seem to be working properly.
As I type it has the VS051 at Tobago already when actually it is still in transit and a couple of hours out. It is actually due at 13.47 local which is 18.47 UK time.
Is this as a result of the time change perchance? ?|
PS Status Update shows the accurate position.
#773445 by mitchja
31 Mar 2011, 17:12
Whilst the flight number is VS75, it's only a positioning flight LGW>MAN.
#773446 by Neil
31 Mar 2011, 17:16
This data is from a direct feed from VS, so it should be accurate, of course things will go slightly amis from time to time.
#773498 by HWVlover
01 Apr 2011, 09:18
There is obviously a problem, perhaps, as you say, with the feed from VS.
At the moment Status Update makes no mention of the VS052 ex Grenada/Tobago at all whereas the Flight Status map shows the plane coming in but from Barbados. ?|
