#72913 by seany
11 Aug 2005, 00:51
Paul I don't know if you have seen this or not, just thaught I would point it out.
#72921 by Nottingham Nick
11 Aug 2005, 01:42
Thanks for the link. Sean.:)
For those who haven't noticed, Pete isn't around much at the moment, being extremely busy at the Edinburgh Fringe. Site tweaks and updates may not be as quick as normal 'cos of this.
#72932 by FamilyMan
11 Aug 2005, 09:37
Originally posted by p17blo
Pete et al, When are you planning to add the 343 UCS seat map to the site and update the VTool?
Check out G-VELD on the aircraft database.
Phil (Buffy)
#72939 by p17blo
11 Aug 2005, 10:17
Aha, so it is there. Thanks for you assistance. Also, I know the VS website has it, but I like to stay in one place when doing my research.
#72941 by p17blo
11 Aug 2005, 10:30
For feedback (rather than criticism) that the seat config isn't quite right.
The VS website shows an UC seat config on A, D & K, where as the G-VELD seatmap shows a A section config of A, G & K, and then a B section config of A, D & K
#81158 by Kryten
16 Oct 2005, 17:27
The A343 Suite map doesn't let you add comments yet! I flew on African Queen yesterday and was looking to add some comments but couldn't [:(]
#81162 by Pete
16 Oct 2005, 17:39
Wiring up the comments to the seats takes a bit of time (each individual seat position has to be coded), so I tend to leave it until I'm sure that the map is correct. At the moment there seems to be some small conflicts between the map shown on virginatlantic.com and the "official" plan that the V-Flyer one was based. Nothing too major, but a small inconsistency.
Pete
#81319 by Kryten
18 Oct 2005, 00:13
Pete
Ok, that makes sense. If I had known in advance I would have taken specific notes and pictures :D I'm back on VS8 so can't help there on the way back.
#81324 by Richard28
18 Oct 2005, 00:54
I'm on the "A343 Suite" both outbound and return in 2 weeks (albeit sitting in the back in Y class).
If you need me to do some on site research then let me know!!
Rich.
#81334 by FamilyMan
18 Oct 2005, 09:51
Incidentally Pete,
Is it possible to populate some of the newer seatmaps with the comments from the corresponding but unchanged sections of previous configurations. I am thinking particularly of the the 747LGW configs - Y and some of PE is the same, and the 343's where Y is the same as the old configuration.
Phil (Buffy)
