#8239 by sunny
04 Oct 2005, 22:15
Hi all,
I don't know if this is true but looking at the FAQ's section, the bit about generally doing stuff in your message looks remarkably like HTML. I'm beginning to dabble in it and was just wondering whether my inkling was correct?[:I]
Max
#79656 by preiffer
04 Oct 2005, 22:26
Nearly - it's actually a similar thing, but with different tags.
It's called BBcode - Bulletin Board Code (we disable HTML - you can see that on the left hand side when entering a post/reply - "HTML is OFF")
If you'd like some insight into what BBcode is - here's a handy guide ;)
(Bear in mind that not ALL extensions are implemented on V-Flyer)
#79659 by sunny
04 Oct 2005, 22:32
So close but no cigar[}:)][:I]. Thanks for the quick reply and will have a look into BB code:D.
Max
