Originally posted by pixuk
As I understand it, and it's only second hand info I have on this, the way MaxDSL works is to find the 'best connection' to achieve maximum throughput - but I've heard many reports that this has meant multiple disconnect/reconnects, which can give intermittent performance in normal browsing, and be absolutely disastrous if you're an online gamer (you'll keep being kicked out of World of Warcraft, just as you're about to roll on the Epic Set... [/geek mode off])
That should only be in the first few days at most, while the "Maximum Stable Rate" is established - we pretty much did that one to death towards the end of
this thread
My disconnects were definitely out of the ordinary, and required a BT engineer visit to play with the noise ratio and do a couple of tweaks at the exchange (IIRC) - pretty sure my friend's facing the same problem.
To be fair, PN have acknowledged that the MaxDSL rollout has adversly affected a lot of customers - apparently they're arguing with BT about it.
Michael
