#21555 by JAT74L
18 Oct 2007, 16:04
The screen on my beloved Sony Vaio T1-XP has failed and I'm wondering how much it's going to cost to repair (replace the lcd).
Any ideas?
And, if it's not going to be an economical repair what would you lot recommend as a replacement?
John
#187251 by ukcobra
18 Oct 2007, 16:47
What makes you think the LCD is defective ?
If it works fine with an external monitor, then it could be a cable fault or at worst case a panel issue.
Sometimes you can find panels reasonably priced on eBay, although choose your supplier carefully.
#187389 by VS075
19 Oct 2007, 11:46
Cue Decker and his "don't buy Sony laptops" quote.
#187396 by McCoy
19 Oct 2007, 12:18
*GASP*
If my T1 failed I would be devastated..
[:0] Commiserations pal..
#187453 by JAT74L
19 Oct 2007, 19:05
Because it's cracked and the black lcd "juice" is leaking around the screen. The computer still fires up but it's def a new screen required.
#187530 by jaguarpig
20 Oct 2007, 11:31
:D:D
