Not sure if anyone uses one of these or not but I can recommend it. Full details can be found here
It's basically a currency card , but instead of having to keep topping it up before you travel, it links directly to any UK issued VISA or MasterCard (either debit or credit cards).
It comes with zero currency conversion fees. The only fee it comes with is an ATM usage fee.
You can link multiple cards to the same SuperCard account. It can be used almost everywhere though the maximum transaction amount is £5000 and of course is dependant on your linked card credit limit or account balance.
I've found that one thing it is great for, is buying things online that are in a different currency. There are again no currency conversion fees using it this way.
For example, I've just booked a flight at Delta.com using mine (because Delta.com was the cheapest) so the transaction was in US$. Using my SuperCard has saved me £7.55 on that transaction as there's no currency conversion fee.
It links to an app where you can see your running totals and all transactions. I've got 7 transactions on mine up to now which has saved me nearly £29 in fees so far!! From the app you can also add, remove and set which payment card to use if you have more than one.
The only minor issue is that you cannot link any AmEx card to it unfortunately. Also you cannot change it's PIN number .
James Mitchell
James Mitchell
