#963512 by Janeclar
07 Mar 2024, 18:38
In previous years I have booked MAN - ATL - RSW return online in PE. I have then looked for UC availability on the MAN- ATL segment, phoned and upgraded with points. The Delta segment has remained in Comfort +. Is this no longer possible?
I am reluctant to book separate segments due to possible delays and having to collect my suitcase in Atlanta on the way home.
Thanks for your help.
#963514 by CommanderB
07 Mar 2024, 20:03
That should still be possible. I did something similar in December.
Naturally it has to be ticketed on a VS 932 ticket though. If you book with Delta directly, this won't be possible.
#963516 by David1946
08 Mar 2024, 03:47
We are currently in Naples and booked our flights last August. We booked PE and upgraded with points and have Delta Comfort and UC on our return later this month. So hopefully it is still an available option.
#964890 by dmc
05 Sep 2024, 15:14
Does anyone know if this should be possible with a credit card upgrade voucher as well? i.e. a cash Premium multi-segment trip (looking at LHR > JFK > DEN, with the JFK > DEN part operated by Delta), upgrading the LHR > JFK segment to Upper with a credit card voucher? I wasn't sure if you can mix a reward segment with a revenue one (which would be the end result).
#964896 by CommanderB
05 Sep 2024, 20:50
I’m fairly sure that’s doable. I’ve upgraded a single segment (LAX>SEA>LHR) with points where only the VS metal leg was upgraded. The voucher just negates the points so it should be fine. Be clear with the agent you only want to Upgrade the VS metal leg.
Users browsing this forum: David1946 and 193 guests
