Just wanted to add this this. Being London based, I did AMS-LHR-LAX-LHR-AMS, Economy on the way out, UC on the way back, for £1100 in feb
This was with BA between AMS - LHR
seany wrote:So is the ex-DUB trick completely closed now? I just keep getting the "The seats you selected are no longer available" message...
Edit : Nevermind, scrap that. Can't get DUB to work, AMS and BRU are £500 higher. but seem to be getting the same price and seats available ex-MIL, so I'll just do that, all the same I guess!
polb74 wrote:seany wrote:So is the ex-DUB trick completely closed now? I just keep getting the "The seats you selected are no longer available" message...
Ex Dublin is still there and still often the cheapest going transatlantic. Expedia will no longer work when using Aer Lingus so either choose BA flights or use bookers which still works fine with Aer Lingus.
Smid wrote:Dublin route still works. Dates might be strange. ita matrix is the one which shows them up.
Just got DUB->LHR (ba business) LGW->LAS (vs upper) on 23rd December, 7 days back the same way, 1172 ukp. I've paid 1152 ukp to go PE direct before on VS...
Enter DUB (click advance routing)
ba lon vs
Enter LAS
vs lon ba
Choose business class, 23/12/15, 5-8 days, GBP for currency.
Now getting it through an engine to book it. Phone VS with the flight numbers?
Always Chilled wrote:Just back from LAS. Had no problem getting our hold luggage tagged up for LGW. Just said we had a change of plans and used work as the reason for not doing the last DUB trip.
So I'd say to anyone worried, put the puppy eyes on and you should be ok!
gumshoe wrote:Always Chilled wrote:Just back from LAS. Had no problem getting our hold luggage tagged up for LGW. Just said we had a change of plans and used work as the reason for not doing the last DUB trip.
Where was your flight back to DUB from - LGW or LHR?
RyanJW wrote:Top tip. Just have hand luggage! It's not like you can't pick up a toothbrush and toothpaste from a CVS/Walgreens on the corner of SF :-)
With both BA and VS allowing you two pieces of hand luggage, surely there is enough clothes for at least 7-10 days!
tontybear wrote:Just remember the BA and VS hand baggage limits are very different.
BA = 23kg
VS = 12kg
Plane Sailing wrote:Just back from LAS on a DUB-LAX/LAS-LGW/LHR-ORK itinerary. No issues or questions at check in and was checked in only to LGW with no mention of our onward flight to ORK (presumably as they couldn't check us in anyway due to airport change).
Unfortunately we just missed our flight to ORK due to M25 traffic hence we had to go home instead. Never mind
Plane Sailing wrote:Sorry about that,hope you didn't wait too long
It was an EI coded / operated flight so no codeshare issue.
gumshoe wrote:I'm puzzled by BA's very generous hand baggage allowance.
