#408157 by ukcobra
30 May 2007, 14:05
Yes, the companion ticket was issued immediately for me and I did n't spot it for 9 months ! The PE upgrades appeared at the renewal date of my Mastercard.
#408323 by jilly
31 May 2007, 18:06
I have now secured my flights using my free PE upgrades and also booked another UC for July to keep my Au card.
Thank you Richard for all your help.
Jilly
#408328 by NS
31 May 2007, 18:56
Originally posted by HighFlyer
The Y -> PE upgrade vouchers are (allegedly) issued after your anniversary date. If you had the old Mastercard it will be this anniversary date, not the date you switched to the AmEx card. Companion vouchers should be credted as soon as you reach the spend threshold (£15k for the White AmEx).
Is the upgrade a cabin upgrade - can it work PE->UC? or is it only available as an ECON->PE? I was under the impression it was ECON->PE only, but may be mistaken.
#408330 by ukcobra
31 May 2007, 19:33
The companion ticket is just that, it matches whatever you buy.
The Economy to Premium Economy Upgrades are as described, they are not mentioned in any marketing literature as a single class upgrade. So I would not expect for them to be used in any other way. When they appear on your flying club account, it is clearly stated as VAA Credit Card Econ>Premium Reward Upgrade
Mark
#408331 by NS
31 May 2007, 19:48
Thanks Mark! Perfect explanation.
#408364 by stoneman
01 Jun 2007, 07:02
OK, here's another question. As stated the PE reward voucher comes into effect within 30 days of your renewal date, which in my case is 12/08 as the card is issued for 2 years.( I am assuming it is the yearly anniversary, but people have been using the word 'renewal date') I have decided to cancel the card after 1 year as I can't see the value spending £115 on something that I have a hard time using, and that causes embarrassment every time I try and use it. Does this mean that I will not be issued with my voucher, something along the lines of another post awhile back that someones stated that if you are canceling your card you do not receive the points for the last month.[:?]
#415062 by DylanDog
02 Aug 2007, 16:39
Originally posted by Decker
From the rules Jilly
4.3.9 Qualifying fare levels for Premium Economy to Upper Class upgrades and Premium Economy Companion tickets on Virgin Atlantic flights:
Any full Premium Economy fare booked in W or S class.
So you were right
Sorry to drag this up again if its been posted elsewhere but the T&C have now changed to
Any W booking class fare applies.
Looks like the info was correct[:?][:0]
DD
#415067 by locutus
02 Aug 2007, 17:24
Am I correct in that there only has to be a T class ticket available, it doesn't matter about U? That's how the Flying Club explained it to me, that as long as the T is there, they book it as a U and upgrade you. [:?]
#415068 by DylanDog
02 Aug 2007, 17:28
Maybe I confused the point by adding it to the Amex thread.
As per the terms and conditions It looks like S fares no longer qualify for companion tickets or upgrades
DD
#415070 by RichardMannion
02 Aug 2007, 17:35
DD
That will be changed back imminently.
Richard
#415072 by DylanDog
02 Aug 2007, 17:37
DD
Richard
Phew ![y]
thanks
DD
EDIT : I'm impressed, they've changed already[:0]
Oh to have that sort of power[;)]
DD
#440656 by adjonline
10 Apr 2008, 15:28
Sorry to bring up an old thread; I just got an unexpected upgrade voucher and am trying to work out if I can use it. I've read through all of the posts, but I'm not sure whether there has to be T and U availability. One post suggests there does, but another that only T availability is needed. I'm assuming that (sadly) both are needed, but if someone could confirm this, I'd be grateful.
#440713 by adjonline
10 Apr 2008, 23:29
U availability by itself, or with T?
#440714 by locutus
10 Apr 2008, 23:58
U on its own. VS will 'create' a T, charge you the miles, and then upgrade it to the U.
#440733 by oxmatt
11 Apr 2008, 09:16
Just to keep on bashing this thread...
Is the validity of the upgrade vouchers the same as the companion vouchers - i.e. one year from date of issue - but the flight itself can be outside the 1 year as long as it is booked before the expiry?
Users browsing this forum: jilly and 40 guests
