#811012 by jwhite9185
17 May 2012, 19:13
muppster wrote:VAST leaves Gatwick on 21/05 at 1400 and arrives at HKG at 0900 on 22/05.......the crew then presumably have a little break and then get on VROM which has a departure time of 1230 on 22/05 and arrives back at LGW at 1825 (all times local)
I think the crew legally need to have a longer break than 3.5 hours on a flight of that duration. Unless a separate crew will be deadheading out on VAST in the suites and the first leg crew will then get their rest on the return?
#811017 by StarGuy
17 May 2012, 19:22
You can't position that far before a duty. A different crew would operate the return sector after having spend several local nights in HKG.
#811246 by jasong
19 May 2012, 19:36
just checked the status updates page and it looks like barbarella is now due to fly out on may 24th now.
just dont know why VA cant open up the seating map for PE based on the fact it will be a config 1 or 2 from april 1st to at least may 24th ?|
jason
#811249 by Kraken
19 May 2012, 20:17
StarGuy wrote:You can't position that far before a duty. A different crew would operate the return sector after having spend several local nights in HKG.
I am fairly certain that all the LGW/MAN 747's that head to/from HKG for refit work will make the positioning flights empty, i.e. no pax & quite possibly no seats in Y on the outbound (as we saw with G-VROM).
As such, these aircraft can fly with next to no crew. Think all you need is the flight deck crew + 1 cabin crew member to do "fire watch", i.e. walk round the passenger areas every so often to check for fires. Must be a very lonely flight for the CC member!
#811275 by Richie
20 May 2012, 02:45
Crew can't fly to HKG and back again with 3.5 hours rest. A crew cannot fly out as passengers in the empty seats and fly the aircraft home as rest has to be in a hotel free of all duty. The amount of cabin crew required on the HKG sector will be two+ as they will have to 'crew rest' during the flight too.
#811706 by PaulS
23 May 2012, 18:27
Is Barbarella back at LGW or still in HKG and if so is the refit complete. VAST is still in service. Looks like the refit timetable is all to c##k. Was hoping for a chance to sample refit on our fligh to MBJ on 1st of July but it looks like VROM will be the only plane in service by then and I believe solely on the Barbados route.
#811708 by Neil
23 May 2012, 18:39
She is still in HKG and due to fly back to LGW tomorrow, with G-VAST due to fly out to HKG on Friday.
There has obviously been a slight delay is getting ROM finished, and they can't afford to have two a/c out of action in one go, so will have just delayed sending G-VAST out until Friday.
I'm not sure I believe the whole, G-VROM will only operate the BGI route thing, it is unusual for VS to operate this way, the only time it has happened is with the A330 first on the VS75 for a month last year until the second arrived, and now with G-VRAY until more arrive, time will tell though.
#811765 by seany
24 May 2012, 02:40
Neil wrote:I'm not sure I believe the whole, G-VROM will only operate the BGI route thing, it is unusual for VS to operate this way, the only time it has happened is with the A330 first on the VS75 for a month last year until the second arrived, and now with G-VRAY until more arrive, time will tell though.
Don't VS have a bit of a history doing that on the BGI route? I remember VFAB operated almost all the VS029/30 flights for an extended period, but not the services that continued onto ANU/UVF.
#811783 by adey2011
24 May 2012, 09:43
Hi all,
I'm flying LGW-LAS in UC in July - am I likely to notice any difference in UC at that time? (I seem to remember there was some kind of deep-clean/repair process going on in UC for the LGW fleet).
Not fussed either way - the UC in the nose of the 747 is always great! Just curious to know if I should see any changes.
#811793 by tontybear
24 May 2012, 11:27
adey2011 wrote:Hi all,
If PE and Y have been refurbished on your flight then UC will have had its 'deep clean' and 'refresh'. And you'll have the JAM IFE system too.
#811829 by adey2011
24 May 2012, 18:22
tontybear wrote:If PE and Y have been refurbished on your flight then UC will have had its 'deep clean' and 'refresh'. And you'll have the JAM IFE system too.
Thanks tontybear - I didn't realise that JAM was a factor! That is definitely something to hope for then, so I'll keep my fingers crossed.
#811830 by jh71283
24 May 2012, 18:33
Seeing as Barbarella has disappeared from the status update page, and there has been no word of her heading back this way, are we to assume she has been delayed even further?
#811831 by PaulS
24 May 2012, 19:02
She has just landed at LGW
#811832 by willd
24 May 2012, 19:12
Correct. VS does have past history of doing this with BGI. IIRC another LHR based 744 also did a stint for a while as well.
#811834 by CHill710
24 May 2012, 19:37
I think that was G-VBIG
#811847 by honey lamb
24 May 2012, 21:11
Over the last three months both G-VHOT and G-VWOW have done runs on the BGI route |:)
The information is in the Toolbox in the Which Aircraft? tab
#811857 by jh71283
24 May 2012, 22:26
Spanishvirgin wrote:She has just landed at LGW
Really? Where did you find this info?
#811864 by pjh
24 May 2012, 23:37
honey lamb wrote:Over the last three months both G-VHOT and G-VWOW have done runs on the BGI route |:)
Back in 2009 we flew back from BGI on G-VWOW. IIRC VS (or VH?) did a mail shot about the purple leather experience being available on the route.
#811928 by RLF
25 May 2012, 13:57
I see VAST has been delayed another 24 hours and not goes tomorrow. I wonder if the old seats would have been removed at LGW within the last 48 hours.
Barbarella must be at LGW now, guess her debut will also be tomorrow, which lucky punters will get the first ride, hope we get a TR soon...
#811929 by PaulS
25 May 2012, 14:07
I watched her come in on FlightTracker app
#811930 by mattyp
25 May 2012, 14:17
G-VAST has just left LGW for a delayed BGI run which was due to be operated by G-VLIP. I imagine the seats are still in situe or this flight could prove a very interesting TR!!
#811931 by PaulS
25 May 2012, 14:34
At this rate refit could take years!!
#812014 by PaulS
26 May 2012, 15:57
G-VAST is finally on her way just passing over the Baltic sea
Users browsing this forum: cooperman, Google [Bot] and 191 guests
