Originally posted by Denzil
jerseyboy, i guess it would be a good idea for you to spend the day as an aircraft engineer, then you might understand. Modern aircraft are very reliable, but can still have faults. The airlines are all run by accountants who hate spending $XXX on a spare part that just sits on a rack at Heathrow, hence parts are shipped from station to station or taken "on loan" from other airlines.....
Exactly what I was just thinking!
As an Engineer I know that management will only hear what they want to hear. The conversations probably go something like this:
Manager: " How long to fix the problem?"
Engineer: "30 minutes if we had the part, but you in your wisdom decided we didn't need to hold an expensive inventory of this part, and we can't get it here in less than 5 hours"
Manager: "Not good enough, get it fixed in an hour"
Manager: "Ok we're good to start boarding the problem will be fixed in time"
Meanwhile the part is put on a courier bike from RR in Derby and is at the mercy of the traffic!
And the management probably kept telling the crew that the problem would be fixed in the next 30minutes, and the engineer kept reminding management that they can not fix the problem without the part.
