#878210 by getinjonathan
16 Jul 2014, 15:15
pblondon wrote:I've just got myself a G on the first flight :-)
It looks like there are still two G's left.
Congratulations! If there are a few of us, we should most certainly arrange a meet at the Clubhouse.
#878866 by markna
24 Jul 2014, 17:19
Interestingly they give a number of 21 aircraft to be delivered in four years. They must have exercised some of their 8 options which I hadnt seen. I believe that VNEW will be rolled out later today.
#878869 by sean.ride
24 Jul 2014, 17:28
markna wrote:Interestingly they give a number of 21 aircraft to be delivered in four years. They must have exercised some of their 8 options which I hadnt seen. I believe that VNEW will be rolled out later today.
My sources have confirmed some of the options have been exercised. Also, I believe VS will exercise them all going forwards.
#878871 by benchsmith
24 Jul 2014, 17:49
anyone noticed the seat plan which is shown inside our 787's tab
talks of a wander wall in PE but can't see it on the plan unless it is the blank space at the front of PE and the galley / kitchen but the eco seat look interesting with the recaro seat and a new design pe seat also am interested to see this may have to grab a flight on one of the new routes
#878875 by clarkeysntfc
24 Jul 2014, 18:24
This was established a while ago. VS are retiring the 5 LHR 747's by the end of 2016 so this explains the uplift of 5 to replace them. The original 16 replace the remaining 340's one for one.
#879219 by hunterdwmgzt
30 Jul 2014, 17:52
Is that plane really going to be ready for a commercial flight by 28th October? It hasn't even got any engines yet! Then all the acceptance/proving tests that will be required. December at best I reckon. Am I being too pessimistic?
#879226 by Darren Wheeler
30 Jul 2014, 21:49
hunterdwmgzt wrote:Is that plane really going to be ready for a commercial flight by 28th October? It hasn't even got any engines yet! Then all the acceptance/proving tests that will be required. December at best I reckon. Am I being too pessimistic?
How long do you think it takes to fit 2 engines?
According to this thread on Airliners.net, G-VNEW is due her Trent engines on Friday the 1st. It seems that once final finishing is done she'll undergo some 30-days worth of tests before being delivered to VS. So I'd guess she'll be handed over early to mid September and go final fitting out (loading IFE, etc.) before commencing crew familiarisation training.
#879230 by Fuzzy14
31 Jul 2014, 01:20
Darren Wheeler wrote:How long do you think it takes to fit 2 engines?
A well trained team used to switching engines with all the right tools to hand could remove an engine and replace it in about 6 hours.
For a new aircraft could do it in less but more likely to have teething issues so say a day each.
#879678 by PaulS
07 Aug 2014, 10:16
Is nobody a little concerned about the reliability of these aircraft and I'm not referring to the batteries / fire problem which seems to gave been sorted. There has just been a thread about the problems Norweigan are having, a two week old Thomson 787 lost an engine mid atlantic this week and BA have had so many teething problems that the crew refer to them as the binliner. With VS having a relatively small fleet the Norwegian problem could easily be repeated.
#879682 by RyanJW
07 Aug 2014, 10:58
Virgin won't have similar problems to Norwegian (DU).
Firstly, VS are a long haul airline and have 30 years experience in this field. DU has none and the 787's were a new project for them to expand. This has meant that the LCC mentality that DU brought to the table with:
- zero (or at least minimal) out station staff
- extremely tight turnaround times for long haul aircraft
- outsourced engineering to Boeing via Gold Care and no in-house engineering team
- a very small LH fleet with almost no replacements within the fleet
have all meant that customer service has suffered when there has been a problem, they don't have the bandwidth to sustain long haul ops if something goes wrong which has a complete knock on effect for the time table. It has meant people sleeping on the floor of LAX for two nights, wet leasing of aircraft from other companies, extremely long delays.
At least VS has spare aircraft that can head on out if a plane does go tech away from base, and they have all of the contracts in place to get parts, do engineering etc that I just don't think DU imagined having seeing as they brought Gold Care from Boeing to supposedly offer this service.
DU will improve, and this has been a very fast learning curve but I have every confidence that the issues will not plague VS in a similar manner.
#879684 by wwings
07 Aug 2014, 11:04
Also VS are starting off with a pretty light schedule of flying.
The first aircraft will only be flying LHR-BOS 6 days a week. It also has about 8 hours on the ground back at base between flights.
Norwegian on the other hand seem to be flying them 7 days a week with very minimal turn times.
#879687 by RyanJW
07 Aug 2014, 11:37
Some of their turnaround times are only 1:30 long! Plus see how hard the DU 787 at LGW is working hard every day!
Mon
LAX > LGW 0135 1205
LGW > FLL 1520 0030+1L
Tue
FLL > FLL 0250 1100
LGW > JFK 1555 0005+1
Wed
JFK >LGW 0135 0810
LGW > LAX 1435 0155+1
Thu
LAX > LGW 0330 1400
LGW > JFK 1720 0130+1
Fri
JFK > LGW 0300 0930
LGW >FLL 1520 0030+1
Sat
FLL > LGW 0225 1035
LGW > JFK 1615 0005+1
Sun
JFK > LGW 0135 0810
LGW > LAX 1245 0005+1
#880619 by mswadley
19 Aug 2014, 01:03
Which day of the week to BOS won't get a 787?
Is it likely to be a 330 on the other day?
Looking for G's for November and would like to try the 787 at least one way.
#880621 by Blacky1
19 Aug 2014, 05:21
mswadley wrote:Which day of the week to BOS won't get a 787?
By doing a few dummy bookings in nov/dec it shows Fridays being operated by an A330 by as always this isn't set in stone
