#10285 by David_Doyle
27 Jan 2006, 21:31
Having had a look at some of the fantastic trip reports regarding SQ's F service, I was thinking of the number of tier points you can earn. It's possible that I'll become VS Gold later in the year and was planning the renewal already [:I]
Looking at the tier point earnings table, you get 7 points for an SQ F sector greater than 2000 miles. So, would I be correct in saying that you could do LHR-SIN, SIN-MEL and back and earn 28 tier points for it? I've assumed that these are always treated as 2 sectors. If so, that's a Gold renewal nearly done....
David.
#95017 by BlackCat
27 Jan 2006, 22:31
Yep. We have LHR-SIN-AKL-SIN-LHR booked in late October and I will be coining in 28 tier points as a result of 4 first class flight segments.
BC
#95018 by Nitrox
27 Jan 2006, 22:37
..and 21 PPS sectors too [y] Only 4 to go...got to be worth a SIN-CGK run BC ?
#95022 by Scrooge
27 Jan 2006, 22:52
Something tell's me Mr BC isn't to worried about doing a quick mileage run,he is a tier point and mileage god to many [oo]
#95024 by David_Doyle
27 Jan 2006, 23:28
BC
Excellent. Thanks for the info BC... it was partly your trip reports which got me so interested in SQ F. Also, looking at the redemption levels for Australia ( 220,000 miles ) it seems a no-brainer to do that compared with the 180,000 for LHR-SYD on VS.
Nitrox - what's the story with PPS sectors? There's not an awful lot of info on FT I can make sense of.
David.
#95097 by Nitrox
28 Jan 2006, 19:21
If you earn 25 PPS sectors in a year, you qualify for SQ's PPS Club
Access to SKL in Singapore is a nice privilege to have if transiting through Singapore frequently as is access to *A Gold lounges around the world.
#95741 by KenJohn
31 Jan 2006, 14:41
These are treated as 2 sectors only because SQ does not use one flight code to cover LHR-MEL. Sectors are determined by flight codes and departure dates.
For example SQ2 SIN-HKG-SFO
Even though there is a stop-over in HKG, a SIN-SFO counts as 1 sector
because one flight code takes you all the way through. If you overnight in HKG or take as separate flight from SIN-HKG and connect to the SQ2 flight for the HKG-SFO, then it will be 2 sectors.
At present, I think all SQ flights via SIN count as 2 sectors since the flight numbers normally change.SQ are fairly efficient at posted their points to VS accounts as well.
