#107056 by mitchja
19 Mar 2006, 20:31
Thanks for the update [y]
That just leaves one J2000 A343 once G-VFLY goes to Finnair in May/June.
#107062 by VS045
19 Mar 2006, 21:18
You have to be pretty unlucky to get J2000 now!;)
VS045
#107064 by mcuth
19 Mar 2006, 21:24
Thanks for the info - fleet database & FAQ updated [y][y]
Question - have BUS & SUN changed regs, and/or are they both under this "lease arrangement"? If they're under a lease, is there any danger they'd come back into the fleet? (just trying to work out if we can remove them from the current fleet d/base and put them permanently in the "retired aircraft" section :))
Michael
#107227 by jerseyboy
20 Mar 2006, 19:14
Michael
G-VBUS is definatly on wet-lease to V-Nigeria and i would assume that G-VSUN would be the same. but not 100% on the latter though
#107276 by G-VOPS
20 Mar 2006, 22:36
No, as jerseyboy points out the aircraft are wet-leased to VK and are operated on the VS UK AOC (Air Operators Certificate) and as such are operated to Virgin Atlantic's standards and procedures, it also means VS have to keep a very close eye on what VK are doing.
#107279 by mcuth
20 Mar 2006, 22:39
Ah ok, thanks for that - I'll leave them in the "current fleet" for now then, with the corresponding note saying they're flying with VK.
Michael
#107389 by Golfman
21 Mar 2006, 15:51
Just for your info - a lot of the staff in Nigeria are actually from the UK, seconded over for up to a year to ensure the VN is run OK and to a high standard
#114970 by mitchja
29 Apr 2006, 11:50
Sorry to drag this back up - but it looks as if G-VFLY has started the process of leaving the VS fleet to join Finnair in June:
VS813P To Dublin, Ireland G-VFLY 340 27/04/2006 19:35
#114971 by honey lamb
29 Apr 2006, 12:03
Hmm! A week too late as far as I am concerned [:(]
