hello - flying to NRT (Tokyo) at end of month (assume on A340)- the on-line virgin seat planner has the toilets on the other side of the aircraft, whereas V-Flyer seating has it directly opposite 2k? seat guru also has it on the other side (hence the seat is the only 'excellent' rated seat UCS.) Just wondered if it should change the seat as not keen on the disturbance if there is a chance i will be next to the toilet! . Thanks!
{Moved to Ask a Guru from Restaurant Guide by Decker}
