Hi PS100
We used OLCI Mon 26th June for our flight to Miami Tuesday 27th June. As far as I can recall, when it says that the check-in has been completed successfully, that is it. If you have completed the API in advance then the information is already held.
When you check-in for your flight, make sure you go to 'baggage drop' not 'DIY check-in'.It can be an easy mistake to make.
On your return journey,if you are flying home from The States, if you check-in on-line, there is a line to complete that says words to the effect 'Permanment Residents Number', enter your passport no. here & then the next line ( I think) says expiry date., enter the expiry date of your passport. It worked fine for the four of us & we had 3 different booking reference numbers.
Have a safe flight, Roxy-Popsy.
