#14099 by mavml
26 Jul 2006, 13:29
In September, on our way back from Tahiti, we are due to change planes at JFK.
We fly into T4 on Air Tahiti Nui and out again on VS from the same terminal.
I understand that we will have to clear immigration, do we then have to go through customs, back to the main VS check in and check in as normal for our onward VS flights, or will we get our boarding cards at Tahiti, and just go and drop our bags back off at a transfer desk somewhere?
We're only on the ground for around 3 hours I think so it could be tight if immigration is busy. I guess that as we are through ticketed, that shouldn't be too much of a worry though as there are 2 later VS flights.
Thanks for any help.
Mark
#129265 by mcmbenjamin
26 Jul 2006, 13:51
Well I do know you will have to clear customs then (assuming you are on a thru ticket, same ticket on VS and Air Tahiti Nu) you will drop your bags at the transfer bag area after customs. Be certian to show your bag check slip to VS at check in/boarding card pick up!
Three hours is plenty of time and as you stay there are two later flights. Also since you say you are thru ticketed, that offer protection.
