In these days of heightened security the travelling public in LGW is advised to use Twilight Check-In. Now I must preface this by saying I have only once flown out of LGW on a VS flight and I didn't use it as my incoming flight arrived well after Twilight Check-In closed. However my understanding was you checked in your cases and basically kept what you would need for the night and on the flight and by and large that would be carried on to the flight. Am I right?
If you look at the prohibited items posted on the Vs website:
Soaps
Creams
Lipsticks or lip balms
Mascara
Toothpaste
Talcum powder
Hairspray and other aerosol items
Deodorants/Sun tanning products
Bottles of contact lens solution
well, they are exactly the items I would need overnight - with the exception of contact lens solution and talcum powder.
OK, you could argue that I can use the toiletries in the hotel I will be overnighting in but it may be that nasty stuff they have in containers screwed to the walls and I have never been able to squeeze them sufficiently to get enough to work up a suitable lather. In some instances the toiletries may be sufficient for me to shower and wash my hair but I have sensitive skin and haven't used soap on my face since God knows when (no cracks about dirty faces, please. I use cream) and I need mousse or gel for my hair which is very fine and will just lie flat without such assistance. Courtesy and compassion for my fellow men tell me I need to use toothpaste and deodorant.
So, I might be able to use what is on offer in the hotels if it is a sufficiently high standard; I might be able to get sample sizes of the lotions, potions and unguents I use; I might be able to root around in a previous amenity kit pre the Scrooge pack and find a sample size toothbrush and toothpaste but it still leaves me without hair mousse/gel, deodorants, lipstick or lip balm and any other make-up I choose to use unless I check it in the following day......
.....which makes a mockery of Twilight Check-In as I still have to check that bag with my lotions, potions and unguents the following day!
Soaps
Creams
Mascara
Toothpaste
Talcum powder
