#14688 by Tim
25 Aug 2006, 20:51
I've looked at the seat rating page, but its not much help.
We've been given 22A & 22C on a 600-con fig2 for our trip to MIA.
Anybody have any experience of these seats?
Thanks in advance
Tim & Chris.
#135241 by mitchja
25 Aug 2006, 21:23
I would be tempted to try and sit a bit further forward if I was you as you will be sat in front of the washroom. The other thing to note is that row 19 doesn't have a window on either side.
#135248 by deep_south
25 Aug 2006, 21:41
I didn't realise 19 didn't have a window - and I'd just updated my booking for my return for Delhi to 19K so I could enjoy the view! I'll change it to 20K, and hope I can see something else besides the wing!
I presume 18 is a bulkhead, held until checkin for babies - does that have a window, and is it worth asking for at checkin? Or might it be available for online checkin?
#135249 by VS045
25 Aug 2006, 22:00
Have been in the back row of config 2 in PE, albeit in the mddle block of 3 and would have preferred to be further forward and away from the WC.
VS.
#135250 by HighFlyer
25 Aug 2006, 22:02
Yup, you can try and request it at check-in, i have sat in row 18 and its probably the best in PE on the Airbus. The seats definitely have windows - and more leg room :)
#135251 by mitchja
25 Aug 2006, 22:07
If you take a look at this photo of a config 2 VS A346, row 19 in PE is where there's no window under the letter 'C' of the Virgin Atlantic logo.
I have no idea why there's no window there though.
I'm going to try and grab row 18 at check-in for my PE A346 flight in December. Currently sat in row 19 going out and row 20 coming back. Can't change seats as PE showing as been full both ways.
#135255 by Tim
25 Aug 2006, 22:17
Thanks for the quick replies.
Just checked the flight and there are no more pre-bookable seats (two together). We'll get to the airport early and try to get row 18.
What time does check-in open for the MIA flight?.
Thanks again.
Tim & Chris.
#135256 by mitchja
25 Aug 2006, 22:20
You can actually check-in for an LHR flight any time from check-in opening at 06:30, although I read today that BAA are now recommending that you don't check-in more than 3 hours before any flight.
#135419 by Neil
27 Aug 2006, 12:50
Totally agree, row 18 is great, you get 2 windows too!!! But to get it you will need to be at CI early!
#135787 by vwaz
29 Aug 2006, 21:17
Hope this isn't a daft question but we are booked in 20 A & C as I didnt want 19 because of the windows. Is it the same on config 2 aircraft or are the seats further forward to get the extra row in? I guess we wont know the config until the day - seat map still shows a config 1.
#135790 by Neil
29 Aug 2006, 21:25
Row 20 is in the same place, to get the extra PE row in on the config 2 a/c they have messed around abit with the Y seating arrangement and position on the toilets etc so the rest of the PE cabin stays the same, I am sure row 20 will be great.
Neil :)
#135792 by mitchja
29 Aug 2006, 21:36
I've just been comparing the PE seat maps for both config 1 and config 2 A346's using the VS seat maps.
Config 2 appears to have row 18 (first row in PE) 1 row further forward than the old config 1 cabins. This would make sense as I cannot see VS wanting to move the washroom further back to fit the extra row of PE seats in. If this is the case then I guess the missing window would now be row 20 [:?]
Some of the VS crew would be best to answer this though!!
#135793 by Neil
29 Aug 2006, 21:42
D'oh - Im Bad, mitchja is totally right and infact the PE on the config 2 could be maybe upto 2 row infront than the config 1 a/c, here is a link to the VS website section that shows the 2 different configs so you can have a look yourself.
Neil:)
#135849 by deep_south
30 Aug 2006, 10:09
Now I am confused...! I am on VS300 to Delhi in PE on 9th Sep. The seatmap on "update my booking" shows PE has 5 rows (18-22), with row 18 after the start of the wing root. The link in the reply above to the virgin site has the a340-600 config 1 with 4 rows of PE, starting at the wing root, and the a340-600 config 2 has 6 rows of PE, starting in front of the wing root!
Aha - I have just sussed it - the seat map on "update my booking" is a A340-300, and not a -600. So even if I do get a window, I'll have a great view of the wing! Or is there a PE seat on a -300 with a good view? D'oh!
#142409 by vwaz
08 Oct 2006, 19:55
I can answer my own question from above now from experience!:)
Row 19 on a config 2 aircraft remains the one without the window.
Didn't like the look of the new row 23 though next to the toilet.
#142530 by radar
09 Oct 2006, 20:25
I am not sure, Denzil or someone else may know, but I suspect it is because this is an area of body join. As PE is around the wing, all models of the A330/340 probably join here, with or without spacers to extend the body length.
#142531 by radar
09 Oct 2006, 20:47
Here is a picture of G-VFIZ in her birthday suit. It kind of shows what I was talking about. I think the blank area may house a mating stringer, to bring the two sections together. But I may be way off. I'm no expert in this area.
