Just noticed Virgin have updated their book flights section. You can now see the class of the ticket, the type of plane you get, look at spending miles, etc. Much better. A nice improvement Virgin!
Brilliant. Really like it, even though it looks odd in firefox
Hallelujah! Ask and ye shall receive
This is almost exactly what I was asking for here.
Nice one! And it seems really fast, certainly much faster than the previous system. There are still a few tweaks I would make, like being able to keep scrolling through sequential 3-day blocks to search for a good fare instead of having to go back to the search option. But with the speed improvement, that is a minor issue. It would also be good to filter on a fare class, so for example just show D class fares.
Hats off to you VS! And thanks V-Ben!
This is going to make my bookings so much easier. Now, if only they could extend this to partner carrier flights.....
Andrew
Andrew
Can you only do this stuff at the time of booking or can you apply upgrades online to a flight already booked????
Still needs a bit of tweaking methinks, but a dramatic step forward and one that VS should be congratulated for.
Problems I see are that 'cabin' doesn't pull down at all, and it seems when I select 'Upper Class - Lowest' from the 2nd screen for the outbound, all options for the return disappear, causing errors.
Hope it gets sorted soon as want to start trying it out in earnest
David.
David.
