#15282 by Vegascrazy
25 Sep 2006, 14:23
I'm sure the answer to this is "no problem" but now we're so close to our holiday I'm in worry mode! Presumably there is no issue using OLCI the day before (to secure seats) and then the CDC taking you to drive through check in the following day? Just thought I should check...I know its not an issue when using normal check-in, ie. OK to have OLCI'd and then use UC check-in at airport.
James
#140596 by preiffer
25 Sep 2006, 14:36
Yup, no problem whatsoever. Just let your driver know you've already checked in. [y]
Users browsing this forum: No registered users and 156 guests
