#141326 by mitchja
29 Sep 2006, 23:40
It usually is quicker just to go to the UC check-in, although you can still check-in online and then drop your bags off at the UC check-in just as long as you are either flying in Upper Class or you are a Gold Flying Club card holder.
#141328 by MarkJ
29 Sep 2006, 23:43
Agree with James - and you will also prob need to collect a Clubhouse or lounge invite!!!
#141333 by ric
30 Sep 2006, 00:05
Ah yes - forgot about the clubhouse invites. Thanks for the quick response.
#141392 by Neil
30 Sep 2006, 13:02
I would always use OLCI and the UC Check in to drop your bags off and collect your clubhouse passes. This way you get the best chance of getting the seat you want and the also have the option of using the quickest queue.
Neil:)
#141681 by ric
03 Oct 2006, 00:20
Well we've already chosen our seats so I'm not sure we'd be gaining that much ?
#141695 by Neil
03 Oct 2006, 08:41
At the moment all you have done is a "pre-selection" of your seats, which does not guarantee them, so there is a chance that they could be taken by somebody else. The only way to confirm your seats is though check in (OLCI or normal), so if you are wanting specific seats it is best to do OLCI.
Also doing OLCI will make your check in at the airport quicker and give you more time to spend in the Clubhouse[y]. Its your choice but there is no harm is doing OLCI, as mentioned you can still use the UC check in desks to drop your bags off and pick up your boarding card.
Neil:)
#141855 by ric
03 Oct 2006, 23:30
Yes, I suppose that could happen...although we do have two small children with us and at the time of booking it was suggested that we adopt the seats that we've been allocated. OK, OLCI it is then.
#141862 by pjh
04 Oct 2006, 00:08
Ric
OLCI will in all probability (unless there's been an aircraft change) default you to the seats you've been allocated. The advantage of using it is that;
a) it gives you best dibs on the (40% of?) seats that are not made available in the preflight allocation phase and so you *may* find a "better" seat has become available.
b) it confirms the seat for you making it less likely you'll find it gone "for operational reasons" when you pitch up at check in.
#144235 by ric
20 Oct 2006, 17:22
Just one more question please...
Is OLCI available exactly 24 hours before the scheduled departure time, or at any time the day before ?
#144240 by Howard Long
20 Oct 2006, 17:34
In my experience it's not available until exactly 23 hours and 59 minutes before the scheduled departure.
Howard
#144260 by McCoy
20 Oct 2006, 19:38
My last flight from LHR, the Bag drop queue was empty (yes, quite bizarre..) and UC check-in was 30 people deep. Having OLCI'd, we went straight to bag-drop.
Why do you mention the need for 'Clubhouse passes'? I don't think I've ever seen one. I just stroll up to the Clubhouse, chat with the girls for a couple of minutes and in I go.
Surely they have a list of UC pax, and your BP is proof of identity, as well as class?
#144330 by baldbrit
21 Oct 2006, 05:50
On my overnight flight (VS10) in November the upper deck is not showing any available seats in UC, but plenty on the lower deck. Is this reserved for the sleep zone, and can only be allocated at check in?
#144335 by Juliet
21 Oct 2006, 10:11
Upper deck on the NYC-LON flights are usually reserved as the snooze zone. Give premier a call and they can allocate one for you.
#144336 by preiffer
21 Oct 2006, 10:26
You may actually find that the snooze zone is full. Quite often, for IAD/NYC/BOS flights, it's the first cabin to fill up - as a lot of people now appreciate the benefit of more time to sleep.
Give Premier a call, but my guess would be that the seats are all taken...
#144590 by ric
23 Oct 2006, 13:10
Well I just did the OLCI. Not smooth I'm afraid. Firstly it refused to let me 'continue' as it said something was missing in my details. It was highlighting the zip code of my hotel which is non-mandatory and was completed anyway. After several attempts I decided to omit it altogether. That worked! Obviously some faulty logic somewhere. Anyway, after having had my preferred seats for nearly a year, it then suggested a completely different set. However, I was then able to re-select my original seats! Is this normal ?
Users browsing this forum: No registered users and 434 guests
