#15511 by gpb_1
08 Oct 2006, 08:26
By some stroke of luck we have managed to upgrade two of our three PE flights from LGW to LAS to UC. (Using a combination of points and pounds). I have booked hair appointments for my son and myself in the clubhouse for 7.15am. (This Sat). Can anyone advise what time I should arrive at check in to get through all the enhanced security checks etc to ensure that I am at the clubhouse on time?
Also, where is the clubhouse in relation to the terminal - would like to have a browse round the shops but not sure if this is far away?
Many thanks for any information
#142356 by Littlejohn
08 Oct 2006, 10:44
An hour should be fine. However you may want to allow a bit longer to have a bite to eat before your treatment and to chill a little.
As you enter the departure lounge the club house is signposted to the right very near the shops. So pretty central.
#142403 by HighFlyer
08 Oct 2006, 19:43
Id allow a little longer, but an hour should be ok. When we flew out of LGW on Friday the queues were horrendous. We estimated 30 minutes to get through as we were flying Upper - but FastTrack was closed so we had to join the very long queues with everyone else. To be fair they do move reasonably well, it just looks dire when you see people queuing through to the shopping areas.
But, when you get to the haven of tranquility that is the CH, you'll be able to chill :)
#142464 by gpb_1
09 Oct 2006, 12:52
Is the fast-track security line still running at Gatwick?
#142465 by Monkey
09 Oct 2006, 12:55
Wasn't when I went in sept
#142511 by gpb_1
09 Oct 2006, 19:22
Thanks for the responses, does anyone know what time check in opens and what time the clubhouse opens?
Many thanks
#142519 by jilly
09 Oct 2006, 19:55
Many thanks
Check in opens at 5.30am and the clubhouse at 7am.
Jilly
#142577 by gpb_1
10 Oct 2006, 07:50
Thanks Jilly, will try to get there around 5.30 then to get through the security checks in a reasonable time.
