#1757 by ports1981
06 Jul 2004, 12:59
We are flying out in November to MCO and are flying PE. I have pre booked our seats and was wondering what will happen if the aircraft changes to the new Suite configuration? Looking at seat maps i can see the configuration of seat numbers is different. I have pre-booked seats 80H-K. Will i be notified of an aircraft configuration change so i can re-select my seats or will i turn up at check in to discover that i have been allocated the worst seats in PE!
#35523 by AlanA
06 Jul 2004, 13:14
Why would you think they would allocate you the worst seats?
If you are a Flyingt Club member, late October, ring the FC and check your seat allocation with them against the scheduled aircraft to be used on the flight (Of course, that could change on the day)do that if you can against PIX's seat page and you should be OK
#35525 by Jonathan
06 Jul 2004, 13:47
additionally nearer the time (within 2 weeks) you could ask freeway nicely what plane you'll be on!
because you may not have a refitted plane..
#35545 by Matt
06 Jul 2004, 17:38
I am flying out to JFK in September and was originally pre-booked on a non UCS flight seat.
I checked now and then on-line at the seat map for my flight until one day it would'nt let me in. I called VS and they advised that the seating configuration had changed and that was the reason that I could no longer go in and check my flight/seating details.
Once advised, they do something to the booking that then allows you back in to re-book the seat of your choice.
They had re-allocated me a seat already (upstairs where my original choice was downstairs), but I just changed it over to what I preferred.
So, there you go, just keep checking on-line.
Matt
