#18818 by Kraken
13 Apr 2007, 22:47
Do any of you VS frequent flyers out there have a new-ish widescreen laptop? If so, can you use it on the in-seat power supply on VS if you travel in UC or PE?
Only asking as I have a new-ish HP widescreen laptop, which takes a 90watt drain off the mains. The in-seat power supply on American Airlines cannot power this laptop, as their maximum current is 75 watts per seat. Is the VS in-seat power system capable of powering these newer laptops with a higher current drain?
I've no objection to buying the Kensington 120watt power adapter for the laptop, but would like to establish if it will / may work on VS first.
James
#167461 by Decker
13 Apr 2007, 22:57
You need to set your Power options in Control Panel. I have a custom option called "In flight". Basically dimmer screen etc. Otherwise you pull too much and the seat power turns off.
#167506 by Bazz
14 Apr 2007, 12:54
Here is the list of supported laptops from the VS site Link
#167510 by RichardMannion
14 Apr 2007, 13:11
That's the list for the supported laptops that they carry the power tips for onboard. There are other laptops that are not on that list that will work if you have the right power tip.
Richard
#167514 by Decker
14 Apr 2007, 13:33
Correct - I have a Sony Vaio VGN-BX197XP which isn't on that list. If I plug it in using my own i-Go it fails to power. If I set the screen brightness lower it is fine.
#167601 by Penfold
15 Apr 2007, 12:12
Bazz cheers for the link, i have been trying to find out whether my laptop would work or not or a while.
I have a Toshiba Satellite L20 (the only model not on the list from what i can tell!) Does anybody know what "tip" i need to get and where from.
Many Thanks
CHRIS
#167605 by Bazz
15 Apr 2007, 12:32
Chris try this link and follow the instructions. You should find what you need. You can also have a look at http://www.igo.com but they do not ship to the UK although they do have a UK affiliate.
#167725 by Penfold
16 Apr 2007, 10:33
Cheers Bazz for the info - very helpful as always
#167730 by mitchja
16 Apr 2007, 10:49
I recently bought myself one of these (I paid less than half that price off eBay ~£40 [:w]). It worked onboard with my HP DV2130EA lap-top without any problems [y] It also means I dont need to take my HP power brick with me either as it also comes with a US/UK/European plug as well.
#167741 by Kraken
16 Apr 2007, 11:12
mitchja - thanks for the [perfect] reply. You have the same model of laptop that I have got, so I'll look out for a Targus power supply on eBay.
James
#167751 by mitchja
16 Apr 2007, 11:35
James
James if you do manage to get one you will need tip S1 which comes with that kit. Re eBay; I bought mine from this person (although they arn't currently selling the APM12EU which is the one you want. Mine was £39.99 including delivery [y]
#167857 by Kraken
16 Apr 2007, 19:36
James - thanks for the info. I'll keep an eye on this eBay sellers auctions and buy the adapter when he next has a APM12EU one up for sale.
James
