#19599 by manymiles
05 Jun 2007, 16:26
I need to travel to LAX the first week of July and the lowest economy fare that is coming up is 747 pounds for an economy return ticket for all dates.
This seems rather steep, checking ExpertFlyer there appears to be seats.
Did I miss a trick here?
#173768 by FamilyMan
05 Jun 2007, 17:03
It does seem a bit steep - I guess it's ramping up for the summer season. The M+M fares offer good savings at this time.
Phil FM
#173775 by preiffer
05 Jun 2007, 17:57
Well...
West coast of the US, peak travel season (July) = high fares? Yup!
#173776 by pjh
05 Jun 2007, 18:18
Expedia and Travelsupermarket suggest that £700+ is the going rate for a direct flight with BA / ANZ / VS.
#173777 by mitchja
05 Jun 2007, 18:21
What about booking a holiday package? VH for example. That sometimes works out cheaper at peak times.
#173778 by preiffer
05 Jun 2007, 18:23
Even the very cheapest, including a stop in MSP (so 2 flights in each direction), with Northworst is £579 + tax/fees.
#173781 by mcmbenjamin
05 Jun 2007, 19:05
Starting August 30 there is MaxJet at about 40GBP more but probably a better value.
#173783 by NS
05 Jun 2007, 19:13
MPM is around £562 in July but availability doesn't look good.
MPN in PE is around £1002 with better availabily??
#173785 by Scrooge
05 Jun 2007, 19:22
For that type of money why not look at Maxjet into Vegas then hop on a shuttle down to lax, ok you spend an extra couple of hours traveling, but in far better seats than VS Y.
#173788 by RichardMannion
05 Jun 2007, 20:41
You could use the 50% off Economy redemption sale to get you into NYC or MCO, and then do a cheap internal. Or there is the 20% off for ORD or IAD.
Richard
#173798 by manymiles
05 Jun 2007, 22:49
Thanks for all the suggestions. The maxjet option really is the most attractive, to LV this time and as I do this nearly every month then to LAX as well.
Users browsing this forum: Joshl257 and 15 guests
