#182471 by gingerflyer
01 Sep 2007, 11:21
You should be able to use this lounge in Sydney airport as a Gold FC member:
Sydney
Upper Class passengers are invited to unwind in the Air New Zealand International Lounge located in Terminal C - enjoy a snack in the cafe, sit back with a drink at the bar or make use of the business facilities.
#182473 by k3nnis
01 Sep 2007, 11:34
Hi gingerflyer,
Thanks for the info :) I'm just worried that you need to be an UC pax to access it unless they treat FC gold just as a UC pax...
#183185 by k3nnis
11 Sep 2007, 15:22
Anyone here entered the NZ lounge at SYD with FC Gold card with either Y or PE boarding pass?:)
#183186 by tallprawn
11 Sep 2007, 15:42
Yep, It's nice and easy.
If you present your AU card at check-in, the agent will give you a VS CH invite which you can use to enter the NZ lounge.
The lounge is a reasonable place to send a few hours at SYD, the views out across the airport are excellent. :D
#183187 by k3nnis
11 Sep 2007, 15:51
Sounds like a good idea to have FC Gold :)
