#254048 by karnsculpture
10 Apr 2008, 21:48
I called up FC today to change an outbound flight - no problem - sorted within a few minutes and a minimal fee to pay. However, I thought there would be a bit more to it...
1) My booking has been changed online - I have kept the same booking reference and can see the new flight number and time (the booking was for a different flight on the same date due to BMI schedule change shenanegans). I could, for example, change the seat allocation if I wanted to. So, I know the change has been made BUT
2) I don't have a new e-ticket to print out - I thought I would be emailed a new version showing that I am on a different flight. Should I just use OLCI and then bring my original e-ticket and the new itinery? Should I be chasing someone at this stage (I fly on Wednesday)
3) My credit card has not been charged. While that is good, I guess, I'm worried in case the booking change hasn't really been done!
#440702 by honey lamb
10 Apr 2008, 22:19
On the Manage my Booking page on the VS website there is a facility for you to request your eticket to be re-sent to you. I think it is entitled 'I can't find my eticket' or something similar. It should send you the amended booking
#440706 by adjonline
10 Apr 2008, 22:25
If the 'Can't find my e-ticket' link isn't present, my experience has been that VS need to do something along the lines of 'reissuing' the ticket: I don't recall the exact term they used. I've had agents expressly tell me there is no need for a reissue, but whenever a reissue hasn't been done, I've not been able to OLCI, and have had to go to ticket desk for a ticket to be reissued there.
#440707 by Kraken
10 Apr 2008, 22:36
A couple of years ago, I did a PE to UC upgrade via the Flying Club call centre. My booking was upgraded immediately (i.e. could select an UC seat straight away online). However, it took VS over 2 months to re-issue my e-ticket & charge my credit card with the upgrade cost (not that I was complaining about this delay!)
Hold in there, you will get a new e-ticket... sometime before you are due to travel.
James
#440722 by gingerflyer
11 Apr 2008, 06:34
you should receive it, although in the past mine has failed to materialise, despite repeat calls to send it again. From memory they then have to re-issue it at check-in, which isn't a problem although in the old days the security man used to look a little bit funny at you if the original was in PE and not UC (the days before the gold card!)
#440730 by karnsculpture
11 Apr 2008, 09:05
Hi Folks,
Thanks for the reassurance. Just received the e-ticket replacement this morning and the change fee is half what I was expecting [:D]
All seems to be present and correct and I have to say dealing with VS has been so much better than BMI.
Best wishes
