#443625 by Neil
16 May 2008, 12:32
Hi Archie
Unfortunately it is pretty difficult to predict any problems/delays etc. It will depend on so many things including which a/c Virgin Ops decide to use on that specific flight, something which they will probably now know (but never released) but even then it could all change. Everything could run on time with today's flights and then a technical problem could happen tomorrow morning, crew could be ill, weather problems, problems caused by pax etc which could all throw the plans out etc.
Fingers crossed everything runs on time for you and you have a great flight, and if you do have a delay try not to let it ruin the start of your holidays, things do happen from time to time which are totally out of everyone's control and at least if it does go wrong you will be in the CH, which is surely the best way to spend a delay[;)]
#443627 by willd
16 May 2008, 13:03
As Neil said you cant really guess what will happen tomorrow.
But this mornings VS27 took off 16 minutes delayed. the 15 which isn't was pushed backed 10 minutes ago when I looked it up.
Enjoy UCS and MCO.
#443630 by virginboy747
16 May 2008, 13:12
Loads are full on your flight tomorrow it's saying you should be on an a/c with odyssey entertainment, so either VAST, VTOP or VXLG
