#459260 by Door013
05 Nov 2008, 17:40
Interesting because I just went to BGI on Jersey Girl in august and it was still it old livery
#459262 by DarkAuror
05 Nov 2008, 17:52
2 months is a long time in the air industry.[;)]
#459264 by mike-smashing
05 Nov 2008, 17:56
Guessing it will have got the new paint when it was cycled through KLM's Maintenance Hangar 14 (which has been named the 'Leonardo da Vinci' hangar - where they do most widebody heavy maintenance and repainting) in Amsterdam during September for a D check.
It was followed in October by G-VROS, and that has since been replaced in Amsterdam by G-VTOP, which I think I still there.
#459269 by slinky09
05 Nov 2008, 18:08
When repainting, presumably the old paint is stripped off - guess they don't use Nitromors?
#459274 by honey lamb
05 Nov 2008, 18:53
No, they sand it down. Takes quite a bit of sandpaper.
#459276 by mike-smashing
05 Nov 2008, 19:06
Depends. I've seen chemical removers used on aircraft before now, as well as power sanding. There is such a thing as 'aviation paint stripper' and it is a relative of Nitromors! [8D]
After all the windows are masked, landing gear poly-bagged, etc., the aircraft is sprayed down with the paint stripper. This is then jetwashed away taking the old paint with it.
In the case of a 747, you do want to remove the old paint first before applying a fresh paint job, because a 747 paint job can weigh between 300 and 500 kgs.
Here's a link to Virgin's G-VBIG on a test flight almost stripped to bare metal.
The additional weight from the decals for the ANZ LOTR 747s was quite impressive too, something like a further 100 kgs.
I'm not sure if G-VFAB's paint weighs more because of the large Varga girl? Anyone know what that did to FAB's ZFW compared to G-VHOT which is of a similar vintage?
#459277 by slinky09
05 Nov 2008, 19:57
Not the greenest of procedures then [:?].
#459278 by Darren Wheeler
05 Nov 2008, 20:04
Somehow I don't think it will go down the drain. More likely (and legally) into a holding tank, then taken away for processing.
Oh, and before the 'waste of money, refurb the Alitalia 5' posts come along.....
Painting is not just a cosmetic/branding thing. The paint helps protect the fuselage from chemical errosion, solar radiation and when polished, gives smoother airflow which increases economy. [:D]
