#257731 by jgm20
18 Jan 2009, 22:19
Hi all,
We've got a big family hols booked from March 22nd to April 4th to MRU. We're all in premium or upper. HOWEVER, I read on a tripadvisor forum that Virgin are stopping the MRU route....is this true and if so from when? I assume they're also flying old Airbus aircraft on such an unpopular route?
the silver lining? My in laws are in premium on the outward leg as there weren't enuf reward seats....could the flight be emptier given the current state of the economy? If so, what is the best way of securing an upgrade via miles or cash?
thanks
#705068 by mitchja
18 Jan 2009, 22:29
VS stops MRU flights April 26th to November 8th, so you will be fine.
As for your comment 'they're also flying old Airbus aircraft on such an unpopular route'
All the LHR A/C have the new PE and Upper Class seats and offer exactly the same level of service so I don't understand your comment [:?]
#705070 by jgm20
18 Jan 2009, 22:39
I just meant the A340-300 with the old inflight entertainment system
thanks for the dates - reassuring
#705071 by mitchja
18 Jan 2009, 22:41
You might get G-VSUN which does have V:Port [:)]
#705533 by jgm20
23 Jan 2009, 08:01
many thanks for this reply - final question
at what point to flying club look at opening up more reward seats on flights if all of them have already been taken? My in laws are in PE on the outbound but FC said they might look closer to the time about opening up seats tho the UC cabin is 70% full already.
might I just be best to wait til the day of departure to ask?
#705536 by Scrooge
23 Jan 2009, 08:54
NO, I would start checking a couple of weeks out and make it a daily thing, sometimes seats open up, sometimes they don't, save the airport for the very last desperation try.
#705815 by jgm20
25 Jan 2009, 22:24
ok thanks
#709148 by jgm20
02 Mar 2009, 21:36
hi - i can't quite understand the aircraft tool - am i right to say there has been a mix of a340-300 and 600 used recently for mauritius? we fly 22/3 and 4/4 back. any thoughts appreciated
#709149 by Scrooge
02 Mar 2009, 21:42
You are correct, 69% 346, 31% 343, right now there is no way to even guess at which type you would get.
#709150 by slinky09
02 Mar 2009, 21:53
Perceived wisdom is to try twice, once about 7 days before departure and then two days before departure. On both occasions if the answer is no ask the call receiver to question the revenue department for a further check.
Finally, ask on check in but then you need miles and the right PE fare code. 24 hrs before departure the central booking team handover responsibility for seats to the airport team, so generally there is no point calling Virgin on the day.
Yup, you are right, 60% 340-600 and 40% 340-300. The difference being the size of the plane and then only whether VPort is the IFE on board.
Looking at Expert Flyer you are currently forecast to have a 343 on both legs. Also EF says that UC only has 3 seats free on the outbound but 7 or more on the return. So you've more chance of getting those necessary upgrades coming home than going ...
#709950 by jgm20
13 Mar 2009, 00:23
many thanks - excellent advice. I saw another post about getting guests into the CH. We currently have 4 of us in UC outbound but 2 in PE. Who should we speak to about getting my in laws into the lounge?
#709951 by Darren Wheeler
13 Mar 2009, 00:35
I take it you mean 4 travelling in Upper with the in-laws in PE?
If that's the case, just turn up the CH reception as say they are your guests. They will need to show their boarding card though. If they are going to arrive late, just give reception their names to save time later.
#710481 by jgm20
19 Mar 2009, 12:52
yes, 4 upper, 2 PE (in laws) - so we are legally OK to bring 2 guests with us?
#710482 by jgm20
19 Mar 2009, 12:55
also, could someone kindly check loads for the outbound flight for sunday esp in PE?
#710486 by Neil
19 Mar 2009, 13:15
Each person flying UC is allowed to take 1 guest in to the CH, so you will be fine.
#710501 by honey lamb
19 Mar 2009, 15:22
As a member of the site you are entitled to 20 free queries on Expert Flyer. If you go to the Expert Flyer forum and use the coupon at the top it will bring you there.
