#258329 by northernhenry
09 Mar 2009, 12:19
Looking at domestic connection flight from LHR,
Arrive at LHR at 19.25 on VS239, there is a BMI leaving for MAN at 20.50pm.
On the assumption we'd be getting our bags chk'd through from HKG to MAN, so just need to clear immigration & change terminal would this be feasible & give us enough time..?
NH
#709660 by Bill S
09 Mar 2009, 12:55
To immigration & terminal change add:
VS punctuality stats (2008), HKG-LHR:
34% Early to 15 mins late
24% 16 - 30 mins late
30% 31 - 60 mins late
12% 61 -180 mins late
edit: Only 10 mins allowed in above for taxi time to Gate.
#709668 by honey lamb
09 Mar 2009, 14:44
Last month I had my bags checked through from Tokyo to Cork (but was not checked in on the ORK leg) The flight landed at 16:30 on to one of the stands around gate 18 - I rather think gate 22. Using Flight Connections for the first time in years I was at the check-in desk airside in T1 at 17:10. My onward flight was at 18:05 and yes, my bags made it also.
Flight Connections at that time was relatively quiet and hassle-free unlike first thing in the morning when long-haul flights world-wide converge on LHR. You would also have the advantage of being checked in for the BD leg at HKG
#709671 by northernhenry
09 Mar 2009, 15:16
Can they do this? Obviously improves matters if so,
and given the evening arrival in UC, quick departure from A/C and Flight Connections across to Term 1, I should be do'able (subject to any delays).
If VS book us to this BD flight & VS HKG leg delayed assume they'd need to put us up for the night?
#709675 by MarkedMan
09 Mar 2009, 18:42
Flight connections can be a breeze at that time, as HL pointed out. In fact, with the much reduced traffic these days, I did a T1 to T5 clean through in about 35 minutes a couple of weeks ago. You do not go through normal immigration, get on a little bus which is efficient, and even in late morning, quite sparsely populated. Even if you have to pick up a boarding pass, I'd still say it's OK, all things being equal.
Like Bill S said, the biggest danger comes from the inbound being late. I was about an hour and a half late arriving in LHR, and no amount of efficiency in transfer is going to help you when that happens [;)]
So it boils down to how much risk tolerance you have for delays. IIRC, the last time I booked a connection through LHR on the same ticket they would not let me book the combo I wanted because it entailed a connection time of 1:20. Minimum was 1:30, they said. Not sure if this will be an issue for you.
Users browsing this forum: Google [Bot], Silver Fox and 15 guests
