#258919 by 2500julian
25 Apr 2009, 18:58
Thought this may be of interest - it's in link below the section where I would normally select my seats concerning baggage allowances on this trip to BGI:
Adult/Child checked in baggage allowance
Two pieces of luggage per passenger, each weighing up to 32kg (70lbs). When added together, the three dimensions of any piece of luggage must not exceed 158cm (62in). [/b]
If I were to print this page off, do you think I could get away with the extra luggage?
#713318 by DragonLady
25 Apr 2009, 19:04
If you're not in UC/PE I personally wouldn't risk it.Excess baggage costs can be prohibitive.
DL
Just seen your other post saying you're in PE so normal allowance.
#713322 by Darren Wheeler
25 Apr 2009, 19:09
Sorry, but I don't see what you mean. That is the standard allowance for Econ/PE to the Caribbean.
#713324 by tontybear
25 Apr 2009, 19:25
econ is 2 * 23
PE is 2 * 32
UC is 3 * 32
Not sure what your query is about
#713346 by 2500julian
26 Apr 2009, 10:23
My final travel documents arrived and they state the baggage allowance is 23KG per person. The website suggests 23KG x 2 per person.
Which is correct?
#713348 by Guest
26 Apr 2009, 11:07
Which is correct?
As above postings - PE is 23kg X 2
#713350 by Neil
26 Apr 2009, 11:34
Which is correct?
PE baggage, is 2 x 32kg, not 2 x 23kg.
I believe the OP has just upgraded to PE, so it means his travel documents are correct.
Here is the link to the VS website baggage info page.
#713351 by Guest
26 Apr 2009, 11:42
Which is correct?
'As above' shuold have made it clear that I had made a typo.
If you read other related postings about travel documents being sent out it is clear they are invaribly incorrect in PE and UC baggage allowance - as the OP IS IN PE then they should be correct regardless of when the upgrade went through.
