#259012 by jasonfj
03 May 2009, 22:42
Does anyone know why recent Apple MacBook power supplies aren't supported on VS flights? As an airline that markets itself toward creative types (like me!) it's a real pain not to be able to work much into a 10 hour flight.
#473962 by Decker
03 May 2009, 23:58
Can you clarify the question? As in, how can you not support a power supply?
#473967 by ukcobra
04 May 2009, 06:22
I can see the airlines point. They have Power Supplies, that have lots of tips. So why does Apple not provide a tip ?
Also, considering the cable is around $69, it's not an expensive purchase if you need to spend time working on the flight.
#473968 by Jeffers555
04 May 2009, 09:01
ISTBC but I thought VS were in the airline business, not a flying electronics store.
If working on the flight is so important why not be creative and buy another battery?[:D]
#473972 by Decker
04 May 2009, 10:16
I did actually wonder if this was an issue with the newer Macs drawing too much current for the in seat power fittings. I know my Vaio has to have its power settings tweaked to work with in seat power otherwise it draws too much current and shuts the socket down.
#473979 by ukcobra
04 May 2009, 12:30
I have the Apple cable, and my Mac works fine in the PE and UC seats. They say the power and cables are not sufficient to actually recharge the battery, but mine slowly did.
#473981 by tontybear
04 May 2009, 12:41
Just because a new laptop / piece of IT equipment hits the market it shouldn't meant that airlines have to rush out and invest in buying new equipment etc to support it.
I would also assume that the airlines would need to have it tested properly to make sure it didn't use too much power, affect other systems and that there was no risk of it bursting into flames. I can't see this being a priority for the airlines or the plane makers
#473982 by mitchja
04 May 2009, 13:13
The Apple Magsafe airline cable isn't designed to charge your Macbook but only to provide power.
It mentions this on the link Darren provided:
quote:Important notes:
Using the MagSafe Airline Adapter provides power for your computer but does not charge the battery.
#473992 by slinky09
04 May 2009, 18:12
As a general rule, laptops should always be started up from the battery, then plugged in after. This stops the shutting down of the power supply!
#473996 by PeterStansfield
04 May 2009, 18:53
Jeffers555
When you say 'get another battery', it's not that simple in Mac land. Unlike the 'bag of bits' that some PC laptops come as, Most Macs come complete and ready to use - Camera, speakers, microphone, and BATTERY 'built in'. It doesn't come to pieces unless you've got a VERY big toolkit, and a lot of guts
#473998 by Tinkerbelle
04 May 2009, 19:09
quote:Originally posted by PeterStansfield
Jeffers555
You can remove my Macbook battery very easily in a matter of seconds - just like any other laptop I've had.
Macbook Battery [:w]
Though I would suggest getting yourself a Magsafe adaptor to use onboard. You could even hire it out to others whilst you sleep and that way it will pay for itself. [}:)]
#473999 by buns
04 May 2009, 19:11
OK I'm convinced - one just ordered[:D][:D]
#474010 by ukcobra
04 May 2009, 22:22
The Mac Air is the only Mac Laptop I am aware of that the battery is not user serviceable.
Mark
