#261700 by catsilversword
24 Dec 2009, 10:47
Sorry, I know it's been asked before, but my search has come up with nothing... does anyone have the geographic number for the premier team?
I do have it at work - but I'm at home....
[:X]
#732615 by tontybear
24 Dec 2009, 10:58
if you have the non geographic number you could try inputting it into
http://www.saynoto0870.com
and see what comes up. There ate often alternatives to 0845 etc numbers too.
#732617 by honey lamb
24 Dec 2009, 11:06
01293 473000
Found on the say no..... website.
Were you using the old number for Premier?
#732618 by catsilversword
24 Dec 2009, 11:20
quote:Originally posted by honey lamb
01293 473000
I was looking up 0844 579 1111....
Thanks!
#732619 by mitchja
24 Dec 2009, 11:21
If you need to call an 0800 number from a mobile and as long as your on contract, use one of the several available freephone dial access numbers.
They are geographical numbers so will just come off you normal call allowance. Obviously this is no use if your on PAYG (although calling a geographical number will still cost you less than an 0800 number).
You dial the access number then enter the 0800 number you need to dial.
The one I also use is 020 0222 0700. You can even put this number in front of an 0800 number in your contact list with a pause in between.
