#262074 by aspence7
26 Jan 2010, 10:01
Can anyone explain to me why the price for a discounted UC fare on the 8/12 LHR to SYD has gone up despite Seatcounter still showing 9+ seats available.
The VS website is defaulting to Z fares, so how do I actually book one of the D fares?
#735377 by Darren Wheeler
26 Jan 2010, 10:06
When searching for UC, you get a choice of cheapest with CDC or without CDC. Use the with option and you might see D if there are no R's available. Otherwise it's a call to FC to get fares.
#735379 by Neil
26 Jan 2010, 10:19
Why do you want a D fare? Z is the lowest and cheapest UC fare, but you don't get a CDC. If you wanted a CDC then R will get you this and is a cheaper fare code than a D. It isn't easy to book a D on line anymore so a call to FC would be required.
#735380 by aspence7
26 Jan 2010, 10:25
Ah Sorry Neil, I've a little confused then. Can you please explain the UC fare codes and what you get with them? I was under the impression that D was the lowest, there's not really a lot of info on the VS website.
#735382 by Neil
26 Jan 2010, 10:36
No problem.
UC fare codes are:
Z- lowest/most restricted/cheapest/no CDC
R - 2nd lowest/cheapest/but you do get the CDC
D - 2nd highest/most expensive/some flexibility/you get a CDC
J - most expensive/fully flexible/you get a CDC.
More detailed information on the restriction for each fare code (apart from R as that is a fairly new code for VS) can be found in the fare codes section on this site.
#735385 by aspence7
26 Jan 2010, 10:54
Fingers crossed there's still 2 Z fares left come monday.
#735388 by Neil
26 Jan 2010, 11:11
If you call UC reservation they will be able to 'hold' specific fares for you for 48hours, so it might be worth calling them on Saturday and getting them to do this for you.
#735389 by aspence7
26 Jan 2010, 11:15
Really, I was unaware they could do that. It's certainly worth knowing.
In that case, would they hold the fare for me, even if on the return leg, I was planning to purchase 2 reward seats?
#735393 by Neil
26 Jan 2010, 11:19
Providing the reward seats are there for them to hold. At worst you could just book a Z return for them to hold and then when you call back on Monday they will be able to change it to the reward fare.
Although I am just questioning if you can book a Z one way and a full G for the return? Not sure that is possible? Or is my brain just being stupid!
#735394 by aspence7
26 Jan 2010, 11:25
If you mean is it possible to book a standard UC fare outbound and a reward seat inbound then yes, I have already had that conversation with the FC and it's fine.
So because the reward seat wouldn't be available until the Monday, as it's stll more than 11 months ahead, I'd have to get them to hold the outbound fare on the Saturday, until the return leg became available?
#735396 by Neil
26 Jan 2010, 11:30
So because the reward seat wouldn't be available until the Monday, as it's still more than 11 months ahead, I'd have to get them to hold the outbound fare on the Saturday, until the return leg became available?
Assume they could do that, although never held just 1 leg of a journey before, so not 100% certain it is possible, guess it is worth a try.
#735397 by aspence7
26 Jan 2010, 11:42
That's the only part i'll need to hold as come monday, the return leg will be available, and I can book it.
But in the meantime, I don't want the outbound fare to go before the return is available.
#735403 by Nottingham Nick
26 Jan 2010, 11:57
But, is a 'standard UC fare outbound' half a Z or half a J? Big difference!
I have never heard of VS allowing cheap one way fares like this. If they do, it opens up a world of possibilities, especially if you are wanting a couple of TPs.
#735406 by Neil
26 Jan 2010, 12:09
That's what I thinking Nick. I know it is possible to book a Z & L/S combo and then upgrade to a G with miles, but I thought that booking a Z/straight G combo wasn't allowed as the outbound is effectively classed as a one way fare.
To the OP, it might be worth giving UC reservations a call and asking them to price it up on an earlier date to just double check what you think you can do is correct, or if in fact, you would have to buy a J for the outbound.
#735407 by aspence7
26 Jan 2010, 12:10
I see your point.
Basically, the fare I was quoted was UC outbound (i'm not sure which class) and a Y fare inbound. It came to around 2600 in total using 60,000 miles for the return.
I also priced up a UC outbound, and a PE inbound, not upgrading or using any miles, it came to 2700
#735409 by Neil
26 Jan 2010, 12:23
I see your point.
It is starting to get a bit confusing now.
Are you planning on buying a UC ticket one way and then an economy ticket for the return and upgrading with miles (60k) OR are you just wanting to use miles (120k) for the return?
The former, upgrading an economy ticket (you should buy an L fare to do this) is okay to combine with a Z UC fare, the latter, just using miles is not allowed.
#735415 by aspence7
26 Jan 2010, 12:40
Sorry, I'm confusing myself too!
It's the first of the two options. I want the cheapest UC outbound, and then coming back, i'll get an ecconomy and upgrade it.
This is because there are no outbound upgrades available, they have already been sold
#735422 by Neil
26 Jan 2010, 12:52
Okay now I understand.
So what you should do when you call FC is ask them to price you a Z outbound and an L inbound. You will then be able to upgrade the L fare to a G fare. This is totally fine and something we do quite a bit ourselves.
#735423 by aspence7
26 Jan 2010, 12:54
Brilliant. Now all I have to do is wait for the G to become available and make sure I get it, otherwise i'll be stuck with a L fare.
And after speaking to an online chat assistant, she tells me that they can put the outbound on hold for 72 hours, which is of extra benifit. Thanks for alerting me to that.
#735428 by aspence7
26 Jan 2010, 13:05
Although there are no Z's left for the outbound, so it will have to be an R
#735429 by slinky09
26 Jan 2010, 13:06
This is where I was confused in a different thread, don't VS make your life difficult by only allowing one way fares in J or W or Y, meaning the most expensive? Certainly if you try online that's what you get. Maybe phoning is different ...
#735439 by Neil
26 Jan 2010, 13:51
I remember that thread.
It is the same when you phone, booking a one way fare has to be either J/W/Y. So you can't combine a discounted fare one way with a full reward the other.
#735443 by slinky09
26 Jan 2010, 14:08
So apsence could book R out and L back (and upgrade to G with miles), but not one way R and then G back? Now I see it, although I don't get it.
#735444 by Neil
26 Jan 2010, 14:10
Yep, that is exactly right.
#735445 by aspence7
26 Jan 2010, 14:14
And booking a Z outbound, i'd then be entitled to a CDC?
Users browsing this forum: No registered users and 45 guests
