#744124 by annievtaylor
22 Apr 2010, 07:34
Never used OLCI before....is it pretty straight forward? Does anyone think this service will be running for my flight on Monday 26th April?
Also....does anyone know if I can check in on the way back from my hotel? I wont be able to print passes though.
#744125 by Neil
22 Apr 2010, 07:36
Virgin have confirmed OLCI is back up and running again. It is very simple to use. If you make sure you have done your API beforehand it makes it even quicker, but it is literally a 2/3min task.
#744127 by Neil
22 Apr 2010, 07:40
annievtaylor wrote:Thank you Neil....then I just print off my boarding cards and go to Bag drop wherever that is??!!
Yes, you can print off your boarding cards, although we never do. When you get to the airport, head to either the bag drop desks, they are clearly marked, or you can use the normal Y/PE/UC desks dependant on which class you are flying. They will tag your bags as normal and print off 'proper' boarding cards for you there.
Enjoy your flight
#744141 by SNOMO
22 Apr 2010, 09:15
As Neil says, don't bother to print off your boarding cards get them at the airport. We printed ours off in February and when we got all the way up to Security and eventually to the front of the q, they would not scan and so we were sent all the way back down to the check-in desk for new ones!!!
Users browsing this forum: Google [Bot] and 47 guests
