#747133 by Pete
01 Jun 2010, 18:59
Put in a couple of tweaks this evening to turn off the chat bar on the iPad (and remove the 'no flash installed' warning on the homepage).
Could iPad users out there give it a test and see if this fixes the problem of the chat bar staying in the middle of the content?
Pete
#747188 by HWVlover
02 Jun 2010, 09:51
Pete, along the same theme, I have that chat bar in the centre of the content when accessing the site by my android phone.
#747197 by slinky09
02 Jun 2010, 13:40
Thanks Pete, when I got around to it I was going to send a Q about the chat bar on my iPad ... but now it's fixed y) .
#747243 by Pete
02 Jun 2010, 21:43
HWVlover wrote:Pete, along the same theme, I have that chat bar in the centre of the content when accessing the site by my android phone.
Crispin was also reporting that problem, and I've been meaning to fix it - need to get the browser string and a few minutes of dev time (and I'm pretty sure Crispin has already told me the browser string...)
#747245 by buns
02 Jun 2010, 21:51
I am sure he did too - only I don't understand morse code let alone computer code :D :D
#747262 by HWVlover
03 Jun 2010, 09:26
Hi Pete, both Crispin and I detailed our browser strings(!!!) here. Apart from the phone model they are the same.
Thanks, David y)
#747267 by Pete
03 Jun 2010, 11:16
I've added Android to the chat bar exceptions - let me know if you're still seeing the bar on your phone.
Pete
#747269 by HWVlover
03 Jun 2010, 11:40
Hi Pete, it is still there but now it moves!
If I go to say Buns recent TR; as the page loads the bar initially appears at the end of the first paragraph after "here endeth the Bad portion of the TR".
As the page loads and smilies appear it disappears and reappears across Jacki's response.
Same thing (the bar moving) happens on other TRs too.
#747271 by Pete
03 Jun 2010, 12:59
Ok, so I'm probably not getting the browser string back as expected then. In theory if it sees 'Android', it shouldn't display at all (much like the way if it sees 'iPad', it suppresses the chat bar).
A tricky one to troubleshoot, as I don't have an Android to try it on (and the emulator is part of a stupidly-huge SDK download...)
#747361 by HWVlover
04 Jun 2010, 17:03
Pete wrote:A tricky one to troubleshoot, as I don't have an Android to try it on (and the emulator is part of a stupidly-huge SDK download...)
Bearing in mind our respective locations mine could be available to you if required y)
#747371 by Pete
04 Jun 2010, 20:21
Good point ;-) Although I'm in my London flat for the weekend.
