#748321 by photoguy
17 Jun 2010, 21:44
greeting from the oc
will be traveling next month LAX-LHR and am planning on carrying on camera bag, medium size roll on and another small case with clothes.
flying UC and website says 2 bags for carry on-does that still apply or has it changed?
thank you
photoguy
#748325 by tontybear
17 Jun 2010, 22:10
And dont forget the dimensions / weight restrictions plus the 100ml rules on liquids for going through security.
Upper Class passengers may take two pieces of hand baggage onboard. Individual dimensions not to exceed 23 x 36 x 56cm, (approx 9 x 14 x 22 inches) and 16kg (35lbs) in combined weight, with no bag weighing more than 12kg. This can include 1 garment bag, 20cm (8ins) thick when folded, not exceeding 12kg in weight.
#748330 by Mandy Hall
17 Jun 2010, 22:58
Depends on how big the camera is...
In addition to the cabin baggage allowance, the following personal items may be carried on board:
* A handbag, pocketbook or purse i.e. which is appropriate to normal travelling dress and is not being used as a container for the transportation of articles which could otherwise be regarded as baggage.
* An overcoat or wrap.
* An umbrella (pointed or/and sharp prohibited) or walking stick.
* A small camera and/or pair of binoculars.
* A reasonable amount of reading matter for the flight.
* Infants food for consumption in flight.
* A small amount of duty free goods.
* Personal headphones may be used as long as they are fitted with the standard 3.5mm jack.
When I checked into IAD, I had a laptop bag and a fairly big handbag and the VS staff member marshalling the line said that I only had one carryon.... (for going through the fasttrack security line).
#748332 by Mandy Hall
17 Jun 2010, 23:24
I'm guessing SLR body and multiple lenses...
D'oh Photoguy's name never registered - been that sort of day... :(
#748335 by photoguy
17 Jun 2010, 23:59
hi
thank you for the replies
yes i will be taking 2 slr camera bodies and 3 lens as i am connecting on to kenya for a safari also on virgin
so the camera bag i am looking at buying fits the dimension stated as does my case for clothes.
just dont want to get caught at the gate and have to check a bag.
thank you
#748337 by honey lamb
18 Jun 2010, 00:23
photoguy wrote:hi
thank you
Gate check is less likely on VS as I would imagine you wouldn't get past check-in without having to check your bags. I'm always fascinated by gate check in the US because it is not that frequent this side of the pond
#748380 by seanpep
18 Jun 2010, 18:09
I did a gate check in flying from charlotte to memphis the bag never made the flight - followed four hours later. Still can't figure out what they did maybe just put it to one side and forgot?
