#753810 by pycroft
27 Aug 2010, 14:22
Hi
Can you someone please help and do a load check on the above flights. I am in PE but thinking of upgrading to UC but the cost is very high so might help make the decision somewhat easier
thanks
Tony
#753815 by slinky09
27 Aug 2010, 14:56
Happy to (unless Neil beats me!):
VS27
J2 D2 R2 Z2 W8 S8 K8 Y8 B8 L8 M7 Q4 X0 N0 O0
VS15
J2 D2 R2 Z2 W9 S9 K9 Y9 B9 L9 M9 Q9 X9 N9 O9
So looks like you'll have plenty of space in PE ... but will be lucky to get those two seats on either flight in J!
#753816 by eejp1007
27 Aug 2010, 14:57
AN28AUGLONMCO/AVS 1 SA 28AUG 0000
1 VS 027 J2 D2 R2 Z2 W8 S8 K8
Y8 B8 L7 M7 Q2 X0 N0 O0
2 VS 015 J2 D2 R2 Z2 W9 S9 K9
Ed
#753817 by eejp1007
27 Aug 2010, 14:59
Oh my god, that's annoying! But smeone picked up 2 seats in q between our two queries! - Ed
#753820 by eejp1007
27 Aug 2010, 15:04
Is the flight available to upgrade with miles?
If it is then that is the only way you are going to sit in UC as it looks pretty full so no op-ups.
#753821 by Neil
27 Aug 2010, 15:05
pycroft wrote:thank you. Is it worth upgrading. I have to buy extra miles to do this which will cost 380 for the two of us?
Are you sure you can upgrade with miles? Just because there are 2 seats available doesn't mean you will be able to upgrade with miles. There must be 'G' reward availability. I would suggest you either give VS a call to check or try a dummy miles booking on the VS site, as I would be surprised if they are miles seats, although ISTBC.
Also, what fare code are you PE seats booked in, you must be in either S or W to upgrade with miles.
#753824 by Neil
27 Aug 2010, 15:13
pycroft wrote:Hi Neil
Not sure what class I am in in PE (they were reward seats) but I rang VS this morning I could upgrade to PE subject to having enough miles (unless this has now changed)
Tony
If that is the case, then I would call VS and put a hold on the mileage seats so that when you buy the miles you know the seats are still there. Nothing worse than someone calling up in the middle of you sorting it out and taking them, leaving you with miles you then can't use!
#753945 by eejp1007
28 Aug 2010, 22:37
Or some of us work in travel and our lives are dictated by a user interface that hasn't changed in 20 years!
Nice and easy to do load checks though....
#Ed
Users browsing this forum: Google [Bot] and 153 guests
