#755395 by slinky09
15 Sep 2010, 12:00
6 October outbound:
J3 D3 R3 Z3 W9 S5 K0 Y9 B9 L0 M0 Q0 X0 N0 O0
13 October inbound:
J0 D0 R0 Z0 W9 S4 K0 Y9 B4 L2 M0 Q0 X0 N0 O0
#755404 by Neil
15 Sep 2010, 13:44
G-VSKY 97 wrote:J3 D3 R3 Z3 outbound, does that mean empty then?
No, that means pretty much full, so with UC full and PE showing W9 S5 K0, which means pretty empty, then there is no reason for you to get an op-up, as they won't be looking to move people from PE to UC.
#755408 by tontybear
15 Sep 2010, 15:28
G-VSKY 97 wrote:J3 D3 R3 Z3 outbound, does that mean full then?
Yes it means that there are 3 tickets left to sell in Upper
You don't add the J3 to the D3 etc to make 12
If a fare class says '9' it means 9 or more tickets available but lower than 9 is the actual number
It means that currently 3 seats but available for all fare buckets. Once the advance periods end the numbers will drop off so shortly it will be J3 D3 R3 and Z0.
If someone buys a fully flex J then the numbers will all reduce to 2.
Users browsing this forum: Google [Bot] and 152 guests
