#756441 by stephencd1
02 Oct 2010, 11:31
Thanks David
do you guys ever say "4 in the front, 10 in the middle and 150 down the back" (or something similar) that way you get a real feeling of the loads.
Stevie
#756443 by David
02 Oct 2010, 11:37
Expertflyer only shows a max of up to 9 empty seats, so you can't really tell how full it is.
You can only look at the lower fare codes and if they are showing 9's as well, it (could be ;)) pretty empty.
#756445 by tontybear
02 Oct 2010, 11:55
BTW you don't add up all the numbers to see how many are available on the plane in total or for a particular cabin.
So for your flight
J6 D6 R6 Z6 W4 S2 K2 Y9 B9 L9 M9 Q9 X0 N0 O0
There are 6 tickets left to buy in UC (J/D/R/Z) fares not 24!
As tickets are sold the numbers will change plus as advance purchase periods expire the number for a code will turn to 0 but the overall number will stay the same.
In PE (W/S/K) there are 4 seats left in total but only 2 of them are in K fare code (the cheapest in PE).
In Econ currently there are 9 or more tickets available. This could mean anything from 9 to the capacity of the cabin !
#756470 by slinky09
02 Oct 2010, 16:10
Decker wrote:Crew have access to real load figures - we mortals don't :)
And nor do we have access to real availability figures, VS's system will show different numbers, because it also calculates the likelihood of no shows on each flight / in each cabin!
#756507 by rich1664
03 Oct 2010, 01:56
slinky09 wrote:And nor do we have access to real availability figures, VS's system will show different numbers, because it also calculates the likelihood of no shows on each flight / in each cabin!
That would be fascinating to see.
I must admit - I've done a couple of no-shows - but that was purely on work business, and they have made the call for me to not take a flight or change a flight etc.
Wonder what the 'average' % is of no shows?
#756511 by Tinkerbelle
03 Oct 2010, 02:51
Well the number of no shows can be quite high for example on a JFK where there are many passengers travelling on full fare flexible tickets so they can change flights without penalty. Compare that to an Orlando flight where nearly everyone is going on holiday (so they're always going to turn up) and on restricted fares then then the no show rate is very, very low.
#756608 by rich1664
03 Oct 2010, 16:22
Tinkerbelle wrote:
That all makes sense, but when you say 'quite high' how high is that?
5%? 10% more?
Users browsing this forum: No registered users and 172 guests
