Does V-Flyer keep statistics on departure/arrival gates or is there a way to see scheduled departure gates for a flight on the day of departure?
Thanks...
Thanks...
MarkedMan wrote:
VS flights in LHR were always a bit all over T3 for me, though very rarely departing from 13-22; I don't think I flew out of those gates more than once or twice, they seemed to serve primarily AA and UA, now maybe AA and BA.
crispin wrote:MarkedMan - you need to take VS19 - I have gone from 17-22 my last 5 trips out here (all this year ...)
jensenma wrote:Which was my main point for asking the question. Basically, is there really a need to leave CH at first Call, 55 mins prior to flight when flying UC? Last flight from lhr on overseas on vs was in january, so has slipped my mind.
Thanks for replies and interesting Reading...
jensenma wrote:.. Basically, is there really a need to leave CH at first Call,
Lizz wrote:The gates won't usually be on the boarding cards because usually at check-in you won't know which gate the aircraft will be coming in on, and even if you do it can change for whatever reason which could then cause confusion for the majority of non-seasoned travellers. Also it can be a case of not bothering to put the gate number in the check-in system to print out on the boarding card.
slinky09 wrote:Lizz wrote:The gates won't usually be on the boarding cards because usually at check-in you won't know which gate the aircraft will be coming in on, and even if you do it can change for whatever reason which could then cause confusion for the majority of non-seasoned travellers. Also it can be a case of not bothering to put the gate number in the check-in system to print out on the boarding card.
I don't get this for VS, with a small fleet, set rotation (unless something goes awry), and turnarounds of 3/4 hrs at LHR, most planes are at their gate when most passengers check in. So I assume it's either a quirk of VS or T3.
Neil wrote:I always thought the reason why they didn't put the gate numbers on the boarding passes was because they wanted people to hang around in the main terminal area with the food/shops for you to spend money in, rather than heading up to the gate area early. The gate areas at LHR are quite small, with no real refreshment facilities or staff until close to boarding time.
Users browsing this forum: No registered users and 146 guests
