#763519 by ec9wrr
08 Jan 2011, 17:42
Hello all,
In a couple of months I will be flying upper on VS019. I've managed to grab seats 12A and 12K as will be travelling with my girlfriend.
My question is, in the A section of Upperclass, what do Virgin use that central area for? I've read elsewhere that this was the treatment are, however, as Virgin no longer offer treatments in flight what is it now used for?
Thanks in advance.
ec9wrr
#763540 by tontybear
08 Jan 2011, 23:00
Ditto on the welcome!
it has been known for persons to stand there and chat and on one flight I was on the crew put a trolly there for a short time dring pre-boarding but otherwise it is just empty space.
BTW there is quite a distance between the A and K sides so no playing footsy with the GF possible.
#763541 by Kraken
08 Jan 2011, 23:09
tontybear wrote:BTW there is quite a distance between the A and K sides so no playing footsy with the GF possible.
Not quite sure that is correct - 12A/K on a config 4 747 are the same seats as 6A/K on a LGW/MAN (config 1 or 2) 747. These two seats are the best ones if you are travelling with your other half. Your ottoman footrests do just about touch each other & you are very close to each other.
#763543 by tontybear
08 Jan 2011, 23:10
D'oh of course they are close. getting my seat numbers confuddled!
#763556 by slinky09
09 Jan 2011, 09:44
Whatever happened to the talk about VS putting changing rooms where the IFBT stations used to be?
#763590 by tontybear
09 Jan 2011, 19:27
The 'spring' menu starts in March (it changes every three months in UC) so look out for it in early March once a member has been on a flight where it has been served and then posts it!
btw am not convinced about filling that space with a changing room - it would stop that part of the cabin being so open which is one of its attractions.
#763596 by ec9wrr
09 Jan 2011, 20:14
Ah I see. I look forward to enjoying the extra space then! I've only even flown UC on airbus, so the 747 layout is all new to me.
Thanks for info on menu launch date. I'll keep an eye out.
#763606 by Alex V
09 Jan 2011, 21:13
Agree the open space in the middle makes this an area which is light and airy, putting a changing room would close this area right in therefore losing the illusion of space.
cheers
alex
Users browsing this forum: No registered users and 181 guests
