#767889 by TankEngine
16 Feb 2011, 09:08
Morning
Just a quick question with regards to the Private Channel Security access at the Upper Class checking area.
Is there access to this other than the lift? Just my wife will not use lifts!
cheers in advance.
#767892 by slinky09
16 Feb 2011, 09:17
Yes, there is an escalator opposite UC check in, go up that, look to your left and you'll see a small WH Smiths and just to the left of that is the entrance.
VS readers take note - it's getting busy and slow!
#767916 by tontybear
16 Feb 2011, 10:44
Yes, if you are facing the UC desks the escalator is to your right and slightly to the back of you.
When you get off the escalator you need to turn left and you will see the door and a little intercom thingy on the wall that you scan your barcodes on your BPs and the door then opens.
Users browsing this forum: Google [Bot] and 171 guests
